M20
Sump Gasket
The M20 block is a cast iron design with six cylinders bored out to make the various engine capacities from 2.0 to 2.7 litres. The block can be identified by checking the number stamped on ...
Bear in mind that although the M20 engine was also fitted to the E34, engines from that car have the dipstick located in the sump. However, an aperture exists on the block, ready to be tapped, and the sump fitted to E30s bolts straight on to relocate the dipstick to its normal position.
The main shaft of the crank is held in place with 'caps', inside which are simple steel bearings called 'shells'. The caps and shells fit around the shaft at fixed points called 'journals'. From the journals, arms known as 'webs' extend outwards to hold the 'throws', while the throws themselves connect to the piston rod or con rod.
The piston rods connect the pistons to the crank, and greatly determine the power characteristics of the engine. The longer the rod, the more time the piston will spend at TDC
M50 rods are compatible
Piston Rings
Crank Pulley
Cam
Rocker Arms
Breather Hose
Engine Mounts
Oil
Oil is picked up by the oil pump and
Oil Cooler
Main article: Cooling
Not Starting
Oil Leaks
Stroker Engines
Engine Management
