M20
Revision as of 20:38, 3 November 2011 by Grrrmachine (talk | contribs)
Models
M20 Oil pump and sump gasket
Sump Gasket
The M20 block is a cast iron design with six cylinders bored out to make the various engine capacities from 2.0 to 2.7 litres. The block can be identified by checking the number stamped on ...
Bear in mind that although the M20 engine was also fitted to the E34, engines from that car have the dipstick located in the sump. However, an aperture exists on the block, ready to be tapped, and the sump fitted to E30s bolts straight on to relocate the dipstick to its normal position.
While the block determines the maximum capacity for the engine, the crankshaft determines to a large extent the stroke of the engine, and therefore the actual capacity. Mounted to the bottom of the block, the crank holds the bottom of the piston rods and converts their up/down motion into rotary force known as torque. It does this by holding the rods on a series of lobes which extend away from the centre of the crank by a certain distance.
  • 320/6 - 71mm stroke
  • 323i - 76mm stroke
  • 325e - 81mm stroke
  • 325i - 75mm stroke
M20 Pistons
Ø: 84 84 84 84 84 84 84
ÜH: 4.2 4.2 4.43 3.6 0.65
MT: -6.2 -5.1 1.1 -3.5 -2
Stroke: 75 75 75 81 81 81 81
Piston Rings
Crank Pulley
Cam
Rocker Arms
Breather Hose
Engine Mounts
Oil
Oil is picked up by the oil pump and
Oil Cooler
Main article: Cooling
Not Starting
Oil Leaks
Stroker Engines
Engine Management
Useful websites
See Also
Engines M21 M30
