Engines
Revision as of 10:57, 8 October 2011 by Grrrmachine (talk | contribs)
List of Engines
316 M10B18
M40B16
1766cc
1596cc
4cyl SOHC 8V Petrol 99hp (66kW) @4500 rpm
102hp (75kW) @4500 rpm
103ft/lb (140Nm) @4250 rpm
105ft/lb (140Nm) @4250 rpm
1982–1990
1988–1995
318 M10B18
M40B18
1766cc
1796cc
113hp (85kW) @4500 rpm
122ft/lb (165Nm) @4250 rpm
1982–1990
1987–1995
318iS M42B18 1766cc 4cyl SOHC 8V Petrol 140hp (104kW) @4500 rpm 127ft/lb (172Nm) @4250 rpm 1989–1991
127hp (95kW) @6000 rpm
125ft/lb (170Nm) @4000 rpm
120ft/lb (164Nm) @4300 rpm
1982–1985
1985–1991
212hp (158kW) @6750 rpm
176ft/lb (0Nm) @4750 rpm
170ft/lb (0Nm) @4600 rpm
1986–1988
1989–1991
Maintenance
Special engines
Fuel
Main article: Fuel
On carburettor engines, the fuel rail, injectors and fuel pressure regulator are replaced by a carburettor, which connects to the inlet manifold.
Air
Main article: Intake
Spark
Main article: Ignition
Engine Management
Main article: Cooling
Oil
Main article: Oil
Engine Swaps
