Bodywork
The E30 body shell is a monoque of mild steel, with a front subframe carried on chassis rails and a rear subframe mounted to the floorpan.
Shell
Panels
All other panels are bolted on and are considered removable. These are:
- Front Valance
- Front Wings
- Bonnet
- Sunroof - if fitted
- Front Doors
- Boot lid - except Touring
- Tailgate - Touring only
- Roof - Cabriolet only
Bumpers
These two styles of bumper are not interchangeable; significant body work needs to be undertaken to convert the front and rear valances to accept the different type of bumpers. Despite the labour involved, it is possible to convert a facelift to a pre-lift, and has been done to a number of cars, including two Tourings belonging to Zone members
As well as the chrome/plastic differences, bumpers are not standard across the range. All front bumpers are compatible (so all plastic front bumpers will fit all facelift cars), but rear bumpers differ between saloons, and convertibles and tourings. Cabriolet and Touring rear bumpers are longer at the sides, because the rear quarter panels on these vehicles are longer. Therefore, fitting a saloon rear bumper to a touring will show a significant gap between the end of the bumper and the edge of the wheel arch. Because tourings were never available with chrome bumpers, this makes cabriolet chrome bumpers increasingly valuable due to their model- and age-restricted scarcity.
Windows
Windscreen
Door windows
Main article: Door windows
Over time, the mechanisms that control your windows can stick or become misaligned, leaving gaps between the window and the door frame. If your windows are in a bad shape, learn how to adjust your front windows.
Quarterglass
Trim
Chrome and Shadowline
Badges
Learn how to replace your badge here.
Body Kits
Main article: Body Kits
Maintenance
Problems
Rust
