Engines
Revision as of 05:58, 4 October 2011 by Grrrmachine (talk | contribs)
List of Engines
Name Volume Engine Valvetrain Fuel Output Torque Engine code Years
316 1766cc
1596cc
4cyl SOHC 8V Petrol 99hp (66kW) @4500 rpm
102hp (75kW) @4500 rpm
103ft/lb (140Nm) @4250 rpm
105ft/lb (140Nm) @4250 rpm
M10B18
M40B16
1982–1990
1988–1995
318 1766cc
1796cc
113hp (85kW) @4500 rpm
122ft/lb (165Nm) @4250 rpm
M10B18
M40B18
1982–1990
1987–1995
318iS 1766cc 4cyl SOHC 8V Petrol 140hp (104kW) @4500 rpm 127ft/lb (172Nm) @4250 rpm M42B18 1989–1991
320i 1990cc 6cyl SOHC 12V Petrol 123hp (92kW) @5800 rpm
127hp (95kW) @6000 rpm
125ft/lb (170Nm) @4000 rpm
120ft/lb (164Nm) @4300 rpm
M20B20 1982–1985
1985–1991
320iS 1990cc 4cyl DOHC 16V Petrol 192hp (143kW) @6750 rpm 155ft/lb (210Nm) @4750 rpm S14 1982–1990
323i 2316cc 6cyl SOHC 12V Petrol 139-150hp (104-110kW) @4500 rpm 0ft/lb (0Nm) @4000 rpm M20B23 1982–19850
325e 2693cc 6cyl SOHC 12V Petrol 127hp (95kW) @4250 rpm 169ft/lb (230Nm) @3200 rpm M20B27 1982–1990
325i 2494cc 6cyl SOHC 12V Petrol 169hp (125kW) @5800 rpm 163ft/lb (222Nm) @4300 rpm M20B25 1982–1990
325iX 2494cc 6cyl SOHC 12V Petrol 169hp (125kW) @5800 rpm 163ft/lb (222Nm) @4300 rpm M20B25 1982–1990
M3 2302cc 4cyl DOHC 16V Petrol 197hp (147kW) @6750 rpm
212hp (158kW) @6750 rpm
176ft/lb (0Nm) @4750 rpm
170ft/lb (0Nm) @4600 rpm
S14 1986–1988
1989–1991
M3 Evolution 2302cc 4cyl DOHC 16V Petrol 197hp (147kW) @6750 rpm 176ft/lb (0Nm) @4750 rpm S14 1987–1987
M3 Evolution II 2302cc 4cyl DOHC 16V Petrol 217hp (162kW) @6750 rpm 181ft/lb (0Nm) @4750 rpm S14 1988–1988
M3 Sport Evolution 2467cc 4cyl DOHC 16V Petrol 235hp (175kW) @6750 rpm 177ft/lb (0Nm) @4750 rpm S14 1990–1990
324d 2443cc 6cyl SOHC 12V Diesel 84hp (63kW) @4600 rpm 112ft/lb (152Nm) @2400 rpm M21D24 1985–1993
324td 2443cc 6cyl SOHC 12V Diesel 114hp (85kW) @4800 rpm 162ft/lb (220Nm) @2400 rpm M21D24 1985–1993
Maintenance
Special engines
Fuel
Air
Spark
Oil
==Engine Management
Engine Swaps
