E30
Revision as of 18:17, 30 September 2011 by Grrrmachine (talk | contribs)
BMW E30
Models
Base models
Name Volume Engine code Years No. Produced
316 1766cc
1596cc
M10B18
M40B16
1982–1990
1988–1995
318 1766cc
1796cc
M10B18
M40B18
1982–1990
1987–1995
89,637
320i 1990cc M20B20 1982–1991
323i 2316cc M20B23 1982–19850 60,706
325i 2494cc M20B25 1982–1990 196,996
324d 2443cc M21D24 1985–1993 75,696
324td 2443cc M21D24 1985–1993 21,514
Sports
318iS 1766cc M42B18 1989–1991 41,234
M3 2302cc S14 1986–1991 17,184
M3 Evolution 2302cc S14 1987–1987
M3 Evolution II 2302cc S14 1988–1988
M3 Sport Evolution 2467cc S14 1990–1990
Overseas Models
South Africa
320iS 1990cc S14 1982–1990 3,748
333i 3210cc M30 1985–1987 204
North America
325e 2693cc M20B27 1982–1990 189,287
325iX 2494cc M20B25 1982–1990 29,589
Variants
Alpina
Hartge
Technical
Engines
Main article: Engines
Main article: Gearbox
Main article: Differential
Main article: Brakes
Main article: Suspension
Steering
Main article: Steering
Body Styles and Fittings
Main article: Bodywork
Electrical
Main article: Electrics
Customisation
Exterior
Interior
Power
M-Technic
Main article: M-Tech
