Engines
| Name | Volume | Engine | Valvetrain | Fuel | Output | Torque | Engine code | Years |
| 316 | 1766cc 1596cc |
4cyl | SOHC 8V | Petrol | 99hp (66kW) @4500 rpm 102hp (75kW) @4500 rpm |
103ft/lb (140Nm) @4250 rpm 105ft/lb (140Nm) @4250 rpm |
M10B18 M40B16 |
1982–1990 1988–1995 |
| 318 | 1766cc 1796cc |
M10B18 M40B18 |
1982–1990 1987–1995 |
| 318iS | 1766cc | 4cyl | SOHC 8V | Petrol | 140hp (104kW) @4500 rpm | 127ft/lb (172Nm) @4250 rpm | M42B18 | 1989–1991 |
| 320i | 1990cc | 6cyl | SOHC 12V | Petrol | 123hp (92kW) @5800 rpm 127hp (95kW) @6000 rpm |
M20B20 | 1982–1985 1985–1991 |
| 320iS | 1990cc | 4cyl | DOHC 16V | Petrol | 192hp (143kW) @6750 rpm | 155ft/lb (210Nm) @4750 rpm | S14 | 1982–1990 |
| 323i | 2316cc | 6cyl | SOHC 12V | Petrol | 139-150hp (104-110kW) @4500 rpm | 0ft/lb (0Nm) @4000 rpm | M20B23 | 1982–19850 |
| 325e | 2693cc | 6cyl | SOHC 12V | Petrol | 127hp (95kW) @4250 rpm | 169ft/lb (230Nm) @3200 rpm | M20B27 | 1982–1990 |
| 325i | 2494cc | 6cyl | SOHC 12V | Petrol | 169hp (125kW) @5800 rpm | 163ft/lb (222Nm) @4300 rpm | M20B25 | 1982–1990 |
| 325iX | 2494cc | 6cyl | SOHC 12V | Petrol | 169hp (125kW) @5800 rpm | 163ft/lb (222Nm) @4300 rpm | M20B25 | 1982–1990 |
| M3 | 2302cc | 4cyl | DOHC 16V | Petrol | 197hp (147kW) @6750 rpm | 176ft/lb (0Nm) @4750 rpm | S14 | 1986–1988 |
| M3 | 2302cc | 4cyl | DOHC 16V | Petrol | 212hp (158kW) @6750 rpm | 170ft/lb (0Nm) @4600 rpm | S14 | 1989–1991 |
| M3 Evolution | 2302cc | 4cyl | DOHC 16V | Petrol | 197hp (147kW) @6750 rpm | 176ft/lb (0Nm) @4750 rpm | S14 | 1987–1987 |
| M3 Evolution II | 2302cc | 4cyl | DOHC 16V | Petrol | 217hp (162kW) @6750 rpm | 181ft/lb (0Nm) @4750 rpm | S14 | 1988–1988 |
| M3 Sport Evolution | 2467cc | 4cyl | DOHC 16V | Petrol | 235hp (175kW) @6750 rpm | 177ft/lb (0Nm) @4750 rpm | S14 | 1990–1990 |
| 324d | 2443cc | 6cyl | SOHC 12V | Diesel | 84hp (63kW) @4600 rpm | 112ft/lb (152Nm) @2400 rpm | M21D24 | 1985–1993 |
| 324td | 2443cc | 6cyl | SOHC 12V | Diesel | 114hp (85kW) @4800 rpm | 162ft/lb (220Nm) @2400 rpm | M21D24 | 1985–1993 |
Maintenance
Engine Swaps
