Steering
Revision as of 13:34, 29 March 2013 by Kedge (talk | contribs)
Rack
Simple overview of Rack & Pinion Steering
Tie Rods
The tie rod is what connects the rack to the wheel hub. At the rack end the tie rod simply screws into the output shafts of the rack, there is an inner and outer ball joint as you can see in the below image. The tie rod itself can be split in two leaving you with the outer part commonly known as the track rod end. The amount this is wound back into the tie rod is what affects the front wheel alignment. The inner ball joint is protected by the rubber gaiters which fit over the end of the rack and then onto the rubber grommet you can see part way down the inner section of the track rod.
Complete E30 Tie Rod.
PAS Pump
The PAS pump is located on the front left hand side of the engine, it take the PAS fluid down from the reservoir and then pumps it under pressure to the rack when the steering wheel is moved, this process makes the weight of the steering much lighter for the driver.The PAS pump is driven by an auxiliary belt so as the belt wears or become stretched the effectiveness of the pump decreases. There is on adjuster bar which allows you to take any slack out of the belt.
Steering Column
This is what connects the steering wheel to the steering rack (via a steering linkage made up of a couple of universal joints). This is simply a tube with the column going through the middle of it, each end of the column is splined for the steering wheel to grip it at the top and the linkage to grip at the bottom, The column is held in place at either end but a bearing, a bunch of washers and clips.
Steering Linkage
This connects the steering column to the steering rack. This is made up of 2 universal joints and is joined together by a rubber coupler, known as a guibo. The universal joints are required due to the steering column being at a different angle to the steering racks pinion gear, while the rubber guibo prevents undue noise transmitting up the column and into the car.
This linkage is held together with four solid rivets, which must be replaced with BMW originals if removed. A 'normal' bolt will put a compression load on the guibo, whereas the shoulders of BMW's special bolts bear against one side of the drive flanges, and the locknuts tighten up against the other sides, thus forming rigidly mounted pins for the guibo, will no loads on it in a direction it wasn't designed to be loaded.
Steering Wheel
Main article: Steering Wheels
The steering wheel is, unsurprisingly, how you steer the car. In genera, two sizes of wheel were fitted to the E30; a 380mm unit, and a smaller, sportier 370mm size which is considered more desirable.
Vague Steering
CNC'd aluminum steering guibo fitted to a 318iS with a Z3 rack.
Fluid Leaks
Fluid leaks are usually from underneath the fluid reservoir located on the left had side suspension turret. The pipes crimped in place can sometime deteriorate so to cure the issue you can either source replacement pipes or trim the end of the old pipes and recrimp using a good quality worm drive hose clip.
It is very rare for leaks to occur occur anywhere else on the pipe system however if removing any of the high pressure hose on the pump or rack it is important to use new crush/sealing washer to prevent future leaks, most E30's use 4x 16mm and 4x 14mm washers.
If you've chased down a leak to the flexi rubber gators on the steering rack itself then it is very likely the seals in the rack have failed and you'll need to be fitting a replacement steering rack.
Maintenance
Changing the Steering Rack
So you've decided to tackle to job of swapping your steering rack, this could be because the old one is faulty or as is becoming more popular you want to fit a rack from another BMW which has a quicker ratio. This guide is applicable for both scenarios as all racks fit in position the same.
You'll need to get the front of the car jacked up and the front wheels removed. Before starting work get the rear wheels choked and the car set on axle stands for safety as you'll be working underneath the car.
First thing to do is separate the tie rod ends from the suspension struts. For better access to each side turn the steering. A 17mm thread lock nut holds the tie rod end to the strut so get this undone and then drop the tie rod from the strut, these two simple tasks can often be fraught with hassle due parts being seized. If when undoing the nut the balljoint is spinning place your jack under the ball joint and take the weight of the strut on the jack and try again to undo the nut, failing that another trick is to use heat such as a blowtorch, this can also work for removing the tie rod from the strut. A hammer and block of wood is also a commonly used way of separating the parts.
The next thing to remove is the linkage that attaches the steering rack to the column. This is secured with a 13mm nut & bolt at both ends, these need removing. The UJ should then slide down the splines towards the rack off the column and can then be pulled off the rack. These are often seized but some penetrating fluid and a couple of knocks with a small hammer should have it moving, there is no need to attack it with a chisel or anything else as brutal.
Now we need to disconnect the pipework. If you're just swapping between E30 racks it'll be easiest to just undo the banjo bolts (19 & 22mm) on the rack itself and drain he fluid there. Fitting a non E30 rack will require custom pipes which will be explained **HERE**.
Now all that is left is removing the rack from its mounting on the crossmember. The rack is held to the crossmember by 2 15mm nuts and bolts, simply undo and remove these. Then to remove the rack the bottom tabs need to be bent out of the way which then allows the room to simply drop the steering rack off the car.
Refitting is as a well-known maintenance manual says, the reversal of removal.
Faster Rack
While the steering of an E30 is a charm of feedback-response, neither too heavy or too light, many of the more spirited drivers find the standard rack too long, in the sense that it takes too many turns from one full lock to the other. Fitting a faster rack from a BMW Z3, E36 or E46 is a common and simple upgrade, here is a guide forfitting a rack from an E36 M3.
E36 steering rack mounted on the PAS subframe holes with head bolt washers used as spacers.
E36 steering rack fitted to an E30 using a DanThe steering linkage and PAS pipes.
The Z3, E36 & E46 racks all bolt straight into position on the subframe like the standard rack so it's just a case of following the process above. However they do need 8mm of spacers as they are thinner than a E30 rack, you can keep their original track rods as well if you desire but certainly with the Z3 and E36 versions they can cause clearance issues if you are running larger than standard brakes. For the spacers you can either have customer ones made up but many have simply used thick washers, 3 head bolt washers are perfect.
However the rest of the install isn't quite so simple due to the different angles of the pinion gear and positioning on the pinion of the PAS feed and return pipes. You can either bend your existing pipes with some trial, error and hope in that you don't kink or split them or you can buy custom pipes (Message E30Zone user DanThe for these & custom steering linkages) or have a local hose specialist make you some. The other issue can be fouling of the steering linkage on the exhaust downpipes/manifold on the 6 cylinder engines again due to the angle of the pinion gear, this is dependent on the engine and manifold you are using, you can either make a custom steering linkage like the one in this guide or one can be purchased from DanThe which involves the use of E34 steering UJs, one of which has to be stripped down and mated to an E30 UJ.
This thread is goes through how to fit a Z3 rack to a 318iS. This is swap is largely the same as above but has an advantage of being able to retain the E30 steering linkage. Modifications are still needed to the PAS pipes and there is also a clearance issue with the plastic under-tray due to the rack now sitting further forward as you have to use the front NON-PAS mounting holes on the subframe, this is easily solved by sawing a section out of the under-tray.
318iS plastic under-tray modified for Z3 rack fitment.
Z3 steering rack mounted in the NON-PAS rack position on a 318iS
