E30
Models
Base models
| Name | Volume | Engine code | Years | No. Produced |
| 316 | 1766cc | M10B18 | 1982–1987 | |
| 316i | 1596cc | M40B16 | 1987–1994 | |
| 318i | 1766cc 1796cc |
M10B18 M40B18 |
1982–1990 1987–1995 |
89,637 |
| 320i | 1990cc | M20B20 | 1982–1991 | |
| 323i | 2316cc | M20B23 | 1982–19850 | 60,706 |
| 325i | 2494cc | M20B25 | 1982–1990 | 196,996 |
| 324d | 2443cc | M21D24 | 1985–1993 | 75,696 |
| 324td | 2443cc | M21D24 | 1985–1993 | 21,514 |
Sports
| 318iS | 1766cc | M42B18 | 1989–1991 | 41,234 |
| M3 | 2302cc | S14 | 1986–1991 | 17,184 |
| M3 Evolution | 2302cc | S14 | 1987–1987 | |
| M3 Evolution II | 2302cc | S14 | 1988–1988 | |
| M3 Sport Evolution | 2467cc | S14 | 1990–1990 |
Overseas Models
South Africa
| 320iS | 1990cc | S14 | 1982–1990 | 3,748 |
| 333i | 3210cc | M30 | 1985–1987 | 204 |
North America
| 325e | 2693cc | M20B27 | 1982–1990 | 189,287 |
| 325iX | 2494cc | M20B25 | 1982–1990 | 29,589 |
Variants
Alpina
Hartge
Dimensions and Weights
| Dimensions | Saloon | Touring | Cabriolet |
| Length | 4325mm | 4450mm | |
| Width | 1645mm | ||
| Height (unloaded) | 1380mm | 1370mm | |
| Wheelbase | 2570mm | ||
| Front overhang | 761mm | 845mm | |
| Rear overhang | 994mm | 1075mm | |
| Front track | 1407mm | ||
| Rear track | 1415mm | ||
| Min. turning circle (wheels) | 9.8m | ||
| Min. turning circle (overall) | 10.5m | ||
| Boot capacity | 404 litres | 312 litres | |
| Weights | 316 | 318 | 318
with catalyst |
320i | 325e | 325i | 325iX | 324d | 325i | 325i |
| Unladen weight | 1000kg | 1010kg | 1020kg | 1080kg | 1120kg | 1125kg | 1215kg | 1155kg | 1275kg | 1355kg |
| Max. weight limit | 1460kg | 1470kg | 1480kg | 1540kg | 1580kg | 1585kg | 1675kg | 1615kg | 1715kg | 1735kg |
| Front axle load limit | 750kg | 7760kg | 760kg | 810kg | 800kg | 800kg | 855kg | 820kg | 830kg | 860kg |
| Rear axle load limit | 825kg | 825kg | 825kg | 825kg | 890kg | 890kg | 900kg | 890kg | 960kg | 945kg |
| Trailer load limits | ||||||||||
| Unbraked | 500kg | |||||||||
| Braked | 1200kg | |||||||||
| Max. roof load | 75kg | 50kg | ||||||||
- for 4-door saloons, add 20kg
- for automatic transmissions, add 20kg
Technical
- Main article: Technical
Engines
- Main article: Engines
- Main article: Gearbox
- Main article: Differential
- Main article: Brakes
- Main article: Suspension
Steering
- Main article: Steering
Body Styles and Fittings
- Main article: Bodywork
Interior
- Main article: Interior
The interior of the vehicle is where the E30 owner experiences the car. From its upholstery to its instruments and everything in between, learn more about the Interior here.
Electrical
- Main article: Electrical
Customisation
Power
M-Technic
- Main article: M-Tech
