Exhaust
Exhaust Manifold
If you are thinking of fitting a Turbo to your M20, then the M21 manifold can be fitted upside down with minor adjustment to the bolt holes. Bear in mind that this will limit your choice of turbo due to the small size of the manifold.
Manifold Studs
Heatshield
Exhaust Pipes
The systems are interchangeable complete,note that you cannot 'pick and mix' between systems, so the centre and rear of a three piece system will not fit the front of a two piece system.
Downpipe
Just like the manifold, the downpipe is specific to each engine.
Centre Box
Catalyzer
Back Box
Lambda Sensor
These oxygen sensors were fitted in line with a catalytic converter in 199 to help reduce emissions. However, vehicles produced before 09/1992 are not required to meet emissions levels, and therefore the catalyzer and lamba can be removed to free up power.
| Part Number | Fitted To | Cable Length |
| 258005313 | E34/E32 | 152cm |
| 258005322 | M50 525i | 145cm |
| 258005324 | E30 325i | 57cm |
| 258005325 | E30 318i | 94cm |
Mounting
Ticking Noise
Broken Studs
Depends where it snaps, If it snaps just below the nut you can just unscrew the stud. But if it snaps below the surface it has to be drilled out and possibly the hole will need to be re-threaded (heli coil or a bigger bolt) this is even more of a problem if its the rear ports because the engine or just the head will have to be removed from the car.
Stainless Systems
Manifolds
We've compiled a list of manifolds so that you can see which manifolds will help your engine, and which ones are just for show.
| Recommended | Not Recommended | |
| M20 | BTB | Fritz's Bitz
Magnex Sebring (LHD only) Supersprint (LHD only) |
| M40 | ||
| M10 |
