M20
Sump Gasket
The M20 block is a cast iron design with six cylinders bored out to make the various engine capacities from 2.0 to 2.7 litres. The block can be identified by checking the number stamped on ...
Bear in mind that although the M20 engine was also fitted to the E34, engines from that car have the dipstick located in the sump. However, an aperture exists on the block, ready to be tapped, and the sump fitted to E30s bolts straight on to relocate the dipstick to its normal position.
The main shaft of the crank is held in place with 'caps', inside which are simple steel bearings called 'shells'. The caps and shells fit around the shaft at fixed points called 'journals'. From the journals, arms known as 'webs' extend outwards to hold the 'throws', while the throws themselves connect to the piston rod or con rod.
Crank Bolt
- M20B20 - 130mm
 - M20B25 - 135mm
 - M20B27 - 130mm
 - M21D25 - 130mm
The 135mm rod weighs 640g.
M50 rods can also be fitted between M20 cranks and pistons, providing either a longer stroke (up to 145mm) or a lighter rod, allowing the engine to rev that much more freely. The M3 or 328i piston rod fitted to the M50/S50 engines are the same dimensions as M20B25 rods at 135mm, but weigh significantly less (540-575g).
Crank Pulley
Cam
Rocker Arms
Breather Hose
The M20 flywheel is a single mass wheel which keeps the engine spinning long after you take your foot off the throttle. It is also the flat surface to which the Clutch mates, ultimately transferring power from the engine to the Drivetrain. The edge of the flywheel is toothed. Known as the ring gear, it is what allows the starter motor to bite onto the engine to start it. The flywheel bots to a pulley at the end of the crank.
On early Jetronic engines, the flywheel also has lugs which are used by the crank position sender to detect engine speed. These earlier engines also have different ring gears, meaning a Jetronic flywheel needs a Jetronic starter motor.
It is very rare for M20 starter motors to fail. If you are having problems starting your car, it is recommended to look at the common problems of E30s before removing the starter motor.
Engine Mounts
Oil
Main article: Oil
Oil Cooler
Main article: Cooling
Coolant flow is regulated by the thermostat, which is controlled by the ECU based on readings from the temperature sensor. A secondary temperature sensor is fitted to drive the temperature gauge in the cabin.
Water Pump
Main article: M20 Water Pumps
Thermostat
Engines need to be at the right temperature to run at optimum conditions, neither too hot or too cold. For that reason a thermostat is fitted to limit the flow of coolant around the system, allowing it to be warmed by the engine. When the temperature is correct, the ECU opens the thermostat to allow coolant to flow to the radiator.
Expansion Tank
For facelift vehicles, an external tank was mounted to the inner passenger wing, to allow hot coolant room to expand. Steam was vented from the system by a drainage tube tucked through a hole in the inner wing, while the tank itself was fitted with a cap to allow fresh coolant to be poured into the system.
Fan
Rubber Hoses
All the elements of the cooling system are linked with a series of rubber hoses. The seven hoses that make up the cooling system are as follows:
Drain Plug
Not Starting
Oil Leaks
Cracked Head
Stroker Engines
The most common option is a 2.8 stroker, which can be built using standard components. Learn more about building a 2.8.
Engine Management
