M20
Sump Gasket
The M20 block is a cast iron design with six cylinders bored out to make the various engine capacities from 2.0 to 2.7 litres. The block can be identified by checking the number stamped on ...
Piston Rings
Crank Pulley
Cam
Rocker Arms
Breather Hose
Engine Mounts
Oil
Oil is picked up by the oil pump and
Oil Cooler
Main article: Cooling
Not Starting
Oil Leaks
Stroker Engines
Engine Management
