E30
Models
Base models
| Name | Volume | Engine code | Years | No. Produced |
| 316 | 1766cc 1596cc |
M10B18 M40B16 |
1982–1990 1988–1995 | |
| 318 | 1766cc 1796cc |
M10B18 M40B18 |
1982–1990 1987–1995 |
89,637 |
| 320i | 1990cc | M20B20 | 1982–1991 | |
| 323i | 2316cc | M20B23 | 1982–19850 | |
| 325i | 2494cc | M20B25 | 1982–1990 | 196,996 |
| 324d | 2443cc | M21D24 | 1985–1993 | |
| 324td | 2443cc | M21D24 | 1985–1993 |
Sports
| 318iS | 1766cc | M42B18 | 1989–1991 | 41,234 |
| M3 | 2302cc | S14 | 1986–1991 | 17,184 |
| M3 Evolution | 2302cc | S14 | 1987–1987 | |
| M3 Evolution II | 2302cc | [S14]] | 1988–1988 | |
| M3 Sport Evolution | 2467cc | S14 | 1990–1990 |
Overseas Models
South Africa
| 320iS | 1990cc | S14 | 1982–1990 | 3,748 |
North America
| 325e | 2693cc | M20B27 | 1982–1990 | 189,287 |
| 325iX | 2494cc | M20B25 | 1982–1990 | 29,589 |
Variants
Alpina
Hartge
Technical
Engines
- Main article: Engines
- Main article: Gearbox
- Main article: Differential
- Main article: Brakes
- Main article: Suspension
Steering
- Main article: Steering
Body Styles and Fittings
- Main article: Bodywork
Electrical
- Main article: Electrics
Customisation
Exterior
Interior
Power
M-Technic
- Main article: M-Tech
