M42
Revision as of 19:48, 17 April 2013 by Grrrmachine (talk | contribs)
M42 engine
Models
M42B18 1.8 L (1796 cc/110 in³) 101 kW (136 hp) @ 6000 175 N·m (129 ft·lbf) @ 4500 6300 1989-96
100 kW (134 hp) @ 5500 172 N·m (127 ft·lbf) @ 4500 6300 1989-96
E36 Differences
If you have bought an E36 lump, you will need to swap the following components to E30-specific parts to fit your car:
Sump Gasket
The block itself is a pearlitic cast iron unit, with a central bore of 84mm and a bore spacing of 91mm. The cylinders have a maximum ovality of: 0.01mm/0.0004" with an identical maximum taper. Compression pressure is 10-11bar (143-156psi), with a compression ratio of 10:1.
  • M44 - 83.5mm stroke
  • M47 - 88mm stroke
The crankshaft has an endplay tolerance of 0.0031-0.0064". If your engine has more than this, consider replacing the pilot bearing.
One size of piston was used for M42 engines, featuring a small dish to provide 20% of the combustion area, as well as notches for valve interference.
M42 Pistons
Engine M42B18 10:1
Year 1989-95
Ø: 84
KH: 31.650
ÜH: 0
VT: 1.650
MT: 4.500
GL: 51.150
BO: 22.0 x 54
Stroke: 81
Conrod Length: 140
Volume 1796
Deck 212.15
Piston Shape: M42Piston.jpg
The standard piston has a diameter of 83.980mm. Three overbore sizes are also available: 84.060mm, 84.230mm and 84.480mm. The clearance is set between 0.0004-0.0016" The piston rings have the following gaps: Top & bottom compression rings = 0.0080-0.0160" ; oil ring = 0.0080-0.0180"
Cams
Being a 16V engine, the M42 head features two camshafts; an Intake and an Exhaust. These cams operate directly on the valves.
Inlet Exhaust
Duration 252 252
Lift 10.2 10.2
Lobe height 1.8755-1.8803"
Valves came with stems in two sizes; 7mm for earlier engines, or 6mm after September 1992. All valves are double-sprung.
Inlet Exhaust
Seat angle 45 degrees 45 degrees
Stem to guide clearance 0.020" 0.020"
Stem diameter 6.975mm 6.975mm
Head diameter 33mm 30.5mm
Seat diameter 31.6mm 29.1mm
Seat width 1.4-1.9mm 1.4-1.9mm
Valve clearance automatic
Timing Chain
Other causes of failure are due to known weak points in the chain gear. The weakest is the steel chain guide, which can fracture and break. An indication of a worn guide is a noticeable increase in chain rattle; the engine will sound significantly louder. Guides can be replaced with an upgraded dealer part made of nylon/plastic. You will need one new 45mm long bolt in conjunction with the new guide.
Breather Hose
Intake Manifold
The inlet manifold is a two pieces design, comprising of an upper and lower manifold. The design is aimed at improving the low down torque of the engine.
If fitting an M42 to your car from an E36, it's not essential to replace the intake manifold; however, there are differences between the E30 and E36 variants. The E30 version is designed for better top-end performance, while the E36 unit yields better torque at lower revs.
Throttle Body
There is a lot of debate regarding M42 flywheels. Some engines were fitted with a dual-mass flywheel while others retained a solid single-mass wheel, which is considered to be more desirable. Dual-mass wheels are more commonly found in the US, while the UK market seems to have retained the single-mass wheel.
Torques
Nm ft-lbs
Big ends - Step 1 23 17
Big ends - Step 2 +70 degrees
Camshaft sprocket 13-17 10-12
Camshaft bearing cap bolts 13-17 10-12
Crankshaft damper 300-320 217-231
Cylinder head Step 1 30-35 22-25
Cylinder head Step 2 +90-95 degrees
Cylinder head Step 3 +90-95 degrees
Exhaust manifold 22-24 17-18
Flywheel 82-94
Intake manifold 13-17 10-12
Main bearings Step 1 20-25 14-18
Main bearings Step 2 +47-53 degree turn
Viscous fan coupling (LH threads) 40-50 29-36
Timing chain tensioner: 23-27 17-19
Profile Gasket
Part Qty Part Number Part Qty Part Number
Gasket 1 111 217 215 46 Gasket 1 116 117 344 90
Bolt set 1 111 217 219 39 Nut 4 183 017 377 74
Valve cover 1 111 217 218 76 Valve cover 3 111 217 214 75
Gasket 1 111 412 478 49 Gasket 1 115 317 211 72
Gasket 1 111 412 478 37 Gasket 1 116 117 346 84
O-ring 1 121 417 272 20 O-ring 1 115 317 212 18
Seal ring 1 071 199 633 55 Throttle-b 2 135 412 474 00
Gasket 1 183 017 119 69 Gasket set 1 111 417 219 19
Antifreeze 1 821 414 677 04
At this stage, most E30 M42's should have had their profile gasket replaced through by a dealer or by previous failure. It would be worthwhile checking with previous owners on when and who replaced the gasket, although you may have to go back a number of years into the car's history. If you cannot determine if it has been replaced, assume that it has, considering the mileage of cars that are now at least twenty years old.
However, keep in eye out for water in oil symptoms (a grey-brown sludge build up easily evident on the oil filler cap or dipstick), unusual oil pressures, water loss (leaks or otherwise) or water temperatures.
Timing Chain Tensioner
  • Timing Chain tensioner part (x1): 113 117 431 87
  • Timing Chain tensioner washer part(x1): 071 199 633 55
Tapping/ticking noise
When most people hear a ticking engine they instantly believe that the tappets are worn. This is not always the case, sometimes it can be a crack in the exhaust manifold. Normally the ticking will go away once the car has been driven for a while, so people believe the the oil has reached operating temperature and cured the tapping problem. However, it could be a small hole in the exhaust manifold that is sealed when the manifold gets hot (ie expanding metal covering the hole up!). This is most common on cylinder one.
Fuel smell
Some times you can smell petrol fumes on startup, which can smell a lot worse if you turn on your fans. This can be a small fuel pipe just behind the inlet manifold which can perish or sometimes just needs the jubilee clip tightening. Petrol cannot always been seen (unless the engine is cold) as the petrol instantly evaporates from the heat of the engine. But you should see the leak leaking onto the fuel rail trim and down the fuel inlet and return pipes for the engine.
Lumpy idle
The M42 engine is prone to the air breather pipes perishing. This results in unwillingness to start on cold mornings and a lumpy uneven idle. If you open the bonnet with the engine running you may be able to hear a hissing sound. Then all you need to play is hunt the sound considering there are a lot of breather pipes to the engine. If there is no hissing sound it could be the valve in the idle control valve (ICV) sticking. Simply disconnect the ICV by undoing the jubilee clips (its found between the engine and bulkhead on the passenger side and is a "T" shape) and spray some carburettor cleaner into the valve. This should stop the valve from sticking, or you could replace the ICV completely.
Loose Sump Bolts
Coil On Plug
Throttle Body Heater Delete
M20 Flywheel
Not all M42's came with dual mass fly wheels which is a common misconception. A cheaper and more road friendly alternative to an aluminium flywheel is to fit an M20 flywheel and clutch assembly.
It is common that the M20 flywheel will rub on the M42 sump. Some people grind down the parts of the sump where it touches, but it is not really the proper way. The best thing to do is get the back of the flywheel machined down,which would be lightening it too so is worth while doing. The flywheel would then have to be balanced.
Chips
Stroker Engines
See also
