Engine Swap - M20
Revision as of 21:07, 22 February 2013 by Grrrmachine (talk | contribs)
The M20 can be fitted to any E30, no matter whether it started life as an M10, M40 or M42. With the right base vehicle a weekend is enough to get everything bolted in and ready to go. You can even use this guide replace your existing M20 with a bigger version, and in that case the engines can be swapped over in a matter of hours.
Parts List
For all swaps, you will need:
  • Full engine with all ancillaries (injectors, AFM, coil, alternator, engine mounts, starter motor and flywheel)
  • Complete engine loom
  • ECU
  • Complete exhaust from manifold to back box
  • M20 Cooling system of radiator inc. brackets, hoses and expansion tank
  • M20 Coding plug for the Instrument cluster
  • New rubber engine and gearbox mounts
  • A mate on standby. An extra pair of hands can save your life.
Engine
Prop
  • 3.91 - Spirited driving, but quite high revs at motorway speeds which can be tiring and noisy
  • 3.73 - Good all-rounder
  • 3.64 - The cruising ratio, which helps claw back valuable fuel economy from the thirsty M20 engine.
  1. Cutting off both C101 connectors and joining the wires directly.
  2. Cut the plug off your old engine loom and join it to your new one.
  3. Get a new C101 plug for your car loom and fit that
  4. Make an intermediary loom to fit between your car and engine looms, using new and old style plugs at either end
Rectangular
C101
Round
C101
Application Image
2 2 Static Oil Level on Check Panel
3 Not Connected
4 4 Temperature Gauge
5 Not Connected
6 6 Oxygen Sensor relay
7 13 Fuel Pump relay
8 18 Ignition start (black/yellow)
9 Not Connected
11 Not Connected
12 Not Connected
13 Not Connected
14 Not Connected
15 10 Dynamic Oil Level on Check Panel
16 5 Oil pressure light
17 11 Reset for Service Lights
18 Not Connected
19 Not Connected
Either of these radiators will need to have a bracket fitted to hold it. If you don't want to do any welding and you aren't happy drilling holes in your car to use ordinary bolts, there is a third solution; a 318iS radiator, which has an expansion tank on the side. You'll just need to get creative with your cooling hoses to make sure it's all plumbed in correctly.
Finally, your radiator is held in place on plastic mounts which clip into holes on the chassis rails. These mounts will be different to your existing radiator mounts, and need to be sourced. They are two different sizes; one short, one long. There have been reports that various radiators don't fit these mounts despite being sold as Genuine BMW radiators, so prepare to be creative with your mounting arrangement, or source another radiator.
Exhaust
Brackets
There are three mounting points that need fettling in order to mount all of your M20 parts. These are
  • Relay bracket - 41141904837
  • Expansion tank mount - 41141871979
  • AFM mount - 41141913049
All of these brackets are on the inner wing. They can be cut off a donor vehicle, or bought new from a BMW dealer using the above part numbers. If you don't want to (or can't) weld, then these brackets can simply be bolted in place as needed.
  • propshaft
  • gear shifter linkage
  • clutch slave
  • rear light switch cable
  • throttle cable
  • coil
  • ECU
