M40
Revision as of 16:34, 10 September 2012 by Grrrmachine (talk | contribs)
The M40 engine was released in 1987, and marked BMW's next generation of four-cylinder engines since the M10. It featured a belt-driven 8-valve OHC design, with an aluminium head on a cast iron block, and was produced in two capacities - The M40B16 of 1.6 litres, and the M40B18 of 1.8 litres. The only internal difference of these two versions was the crankshaft which modified the stroke and therefore overall displacement of the engine.
The E30 was equipped with both versions, powering the 316i and 318i respectively, and continued to use those engines until the end of production in 1994. Both were available with or without a catalyzer.
The M40 formed the basis of all BMW's four-cylinder engines over the next decade. While its direct successor was the M43, it also spawned the 16-valve M42 used in the 318iS, which shares many compatible components. Considering the success of these subsequent engines, it is unfortunate that the M40 itself has proved to be the worst of the E30 engines, with many documented problems and little scope for improvement.
Models
M40B16 1.6 L (1596 cc/97 in³) 75 kW (101 hp) @ 5500 143 N·m (105 ft·lbf) @ 4250 6200 1988
73 kW (98 hp) @ 5500 141 N·m (104 ft·lbf) @ 4250 6200 1988
M40B18 1.8 L (1796 cc/109 in³) 85 kW (114 hp) @ 5500 165 N·m (122 ft·lbf) @ 4250 6200 1987
83 kW (111 hp) @ 5500 162 N·m (119 ft·lbf) @ 4250 6200 1987
The oil pump sits behind the timing case cover, and is directly driven by the crankshaft. It is a gerotor pump (one cog inside another). It is supplied with oil via a pick-up tube into the sump.
In the event of a failing or failed pump, replacement is quite a lengthy process due to its location. It is required to remove al components from the front of the engine, including the timing chain, in order to remove the front end cover of the engine. Then this cover must be removed with care, since the cylinder head fits on top of the case.
Sump Gasket
A single block design was used for all M40 engines, and they are completely interchangeable between models. All blocks use an 84mm centre bore.
Bear in mind that although the M40 engine was also fitted to the E34 and E36. Engines from those cars have the dipstick located in the sump. However, an aperture exists on the block, ready to be tapped, and the sump fitted to E30s bolts straight on to relocate the dipstick to its normal position if you wish. But an E34 sump will fit an E30; an E36 will not.
It is this distance that differentiates the two crankshafts fitted to M40 engines. The sizes are:
M40 crankshafts are compatible with the M42 engine, although they have a slightly different "nose" which may require adapting to accept the M42 pulley/sprocket.
All M40 engines use the same 135mm piston rods.
M40B16 8.2:1 M40B18 8.8:1
87-94
Ø: 84
KH: 36.15
MT: 2.75
GL: 63.5
BO: 22.0 x 54
Stroke: 72 81
Conrod Length: 140 140
Volume 1596cc 1766cc
Piston Shape: M40Piston.jpg
Timing Belt
The M40 uses a belt to drive the valvetrain (unlike the M10 and M42 engines). Therefore, a pulley is mounted at the end of the crankshaft to power the belt, which drives a corresponding pulley on the camshaft. It is recommended to replace this belt and its tensioner every 30,000 miles or three years. Some people recommend 25,000 or even 20,000 miles, just to be safe.
Learn more about changing the timing belt.
The 8V cylinder head on all M40 engines is a cast aluminium unit, featuring a single direct-action cam to operate the valves. The head is interchangeable between E30 and E36 models, but shares no compatibility with other BMW engines such as the M42, due to that engine's use of a timing chain instead of a belt.
Cam
On the M40, an overhead camshaft drives the intake and exhaust valves via tappets. This camshaft is belt-driven, and held in place using 5 bearings. It is lubricated by an overhead oil spray bar.
The cam is the known weak spot of the M40 engine, and is more susceptible to lobe wear than any other E30 engine, usually caused by a blocked oil spray bar. When the cam is worn, the engine won't rev high.
Cam Pulley
The M40 engine features a vernier-style cam pulley, allowing for a few degrees of adjustment in the timing of the engine.
Being an 8-valve engine, the M40 head contains one intake and one exhaust valve per cylinder.
Inlet Exhaust
Seat angle 45 degrees 45 degrees
Stem to guide clearance 0.020" 0.020"
Stem diameter 6.975mm 6.975mm
Head diameter 41.9mm 35.9mm
Valve clearance automatic
Tappets
The M40 engine uses hydraulic tappets to control the valves, meaning no adjustment is required to set the gaps.
However, tappets do get worn over time, usually from oil starvation, leading to an unhealthy ticking sound.
Breather Hose
The M40 flywheel is a single mass wheel which keeps the engine spinning long after you take your foot off the throttle. It is also the flat surface to which the clutch mates, ultimately transferring power from the engine to the Drivetrain. The edge of the flywheel is toothed. Known as the ring gear, it is what allows the starter motor to bite onto the engine to start it. The flywheel bolts to a pulley at the end of the crank.
All M40 starters are interchangeable, and are also compatible with M42 starters.
It is very rare for M40 starter motors to fail. If you are having problems starting your car, it is recommended to look at troubleshooting your engine before removing the starter motor.
Engine Mounts
The engine mounts are standard on all M40-equipped E30s; however, if you are taking an engine from an E34 or E36, you will need E30 engine mounts.
Won't Rev Over 5000
To confirm, remove the rocker cover and baffle plate so that you have access to the cam shaft, and run your finger nail over the cam lobes. If you can feel scratches, grooves or other imperfections, the cam is in a bad condition.
The only solution is to replace. Learn more about replacing an M40 camshaft.
Noisy Tappets
The tappets in an M40 are known for ticking over time. This is usually due to wear from oil starvation. The first thing to do is remove the rocker cover and inspect the camshaft for signs of wear. Each love should be smooth; any scratches or ridges indicate a worn cam which makes it uneconomically viable to replace the tappets; you will have to refresh every part of the valvetrain.
If your cam is in good condition, first try an oil change and a new oil spray bar. This will help keep the tappets lubricated. They will continue to tick on cold start but will hopefully quieten down as the engine warms up. If that doesn't solve the issue, consider replacing the tappets, followers and thrust pads with new items; DO NOT use second-hand parts, considering how common this problem is with M40 engines.
Loose Sump Bolts
Due to the two-part design of M40 and M42 sumps, there is a common issue of internal sump bolts working loose. Not only can this cause oil leaks, but there's the threat of oil starvation to critical parts as the sump gaskets themselves work loose and block essential oil channels. To prevent premature engine death, learn more about M40 sump bolts.
Unfortunately the M40 is not sympathetic to upgrades. There are no simple "bolt-on" solutions that will give an increase in performance. If you are looking for more power, consider an engine swap to the M42 engine, or investing in forced induction.
The best way to get performance out of an M40 is simply to service it.
See also
