E30
Revision as of 15:41, 9 September 2012 by Grrrmachine (talk | contribs)
BMW E30
Models
Base models
Name Volume Engine code Years No. Produced
316 1766cc M10B18 1982–1987
316i 1596cc M40B16 1987–1994
318i 1766cc
1796cc
M10B18
M40B18
1982–1990
1987–1995
89,637
320i 1990cc M20B20 1982–1991
323i 2316cc M20B23 1982–19850 60,706
325i 2494cc M20B25 1982–1990 196,996
324d 2443cc M21D24 1985–1993 75,696
324td 2443cc M21D24 1985–1993 21,514
Sports
318iS 1766cc M42B18 1989–1991 41,234
M3 2302cc S14 1986–1991 17,184
M3 Evolution 2302cc S14 1987–1987
M3 Evolution II 2302cc S14 1988–1988
M3 Sport Evolution 2467cc S14 1990–1990
Overseas Models
South Africa
320iS 1990cc S14 1982–1990 3,748
333i 3210cc M30 1985–1987 204
North America
325e 2693cc M20B27 1982–1990 189,287
325iX 2494cc M20B25 1982–1990 29,589
Variants
Alpina
Hartge
Dimensions and Weights
Dimensions Saloon Touring Cabriolet
Length 4325mm 4450mm
Width 1645mm
Height (unloaded) 1380mm 1370mm
Wheelbase 2570mm
Front overhang 761mm 845mm
Rear overhang 994mm 1075mm
Front track 1407mm
Rear track 1415mm
Min. turning circle (wheels) 9.8m
Min. turning circle (overall) 10.5m
Boot capacity 404 litres 312 litres
Weights 316 316i
318i
318i
with catalyst
320i 325e 325i 325iX 324d 325i 325i
Convertible
Unladen weight 1000kg 1010kg 1020kg 1080kg 1120kg 1125kg 1215kg 1155kg 1275kg 1355kg
Max. weight limit 1460kg 1470kg 1480kg 1540kg 1580kg 1585kg 1675kg 1615kg 1715kg 1735kg
Front axle load limit 750kg 7760kg 760kg 810kg 800kg 800kg 855kg 820kg 830kg 860kg
Rear axle load limit 825kg 825kg 825kg 825kg 890kg 890kg 900kg 890kg 960kg 945kg
Trailer load limits
Unbraked 500kg
Braked 1200kg
Max. roof load 75kg 50kg
  • for 4-door saloons, add 20kg
  • for automatic transmissions, add 20kg
Technical
Main article: Technical
Engines
Main article: Engines
Main article: Gearbox
Main article: Differential
Main article: Brakes
While moving in the E30 is an utterly delight, the need to stop moving is sometimes necessary. For that reason, the E30 was fitted with front discs on all models. The smaller-powered 316, 316i and 318i saloons were fitted with rear drum brakes, while all six-cylinder models and Tourings had rear discs as standard.
Main article: Suspension
Steering
Main article: Steering
Body Styles and Fittings
Main article: Bodywork
Interior
Main article: Interior
The interior of the vehicle is where the E30 owner experiences the car. From its upholstery to its instruments and everything in between, learn more about the Interior here.
Electrical
Main article: Electrical
Customisation
Power
M-Technic
Main article: M-Tech
