Bodywork
Shell
Roof
Main article: Roof
Panels
- Front Valance
- Front Wings
- Bonnet
- Sunroof - if fitted
- Front Doors
- Boot lid - except Touring
- Tailgate - Touring only
Bumpers
As well as the chrome/plastic differences, bumpers are not standard across the range. All front bumpers are compatible (so all plastic front bumpers will fit all facelift cars), but rear bumpers differ between saloons, and Convertibles and Tourings. Cabriolet and Touring rear bumpers are longer at the sides, because the rear quarter panels on these vehicles are longer. Therefore, fitting a saloon rear bumper to a touring will show a significant gap between the end of the bumper and the edge of the wheel arch. Because Tourings were never available with chrome bumpers, this makes cabriolet chrome bumpers increasingly valuable due to their model- and age-restricted scarcity.
Paint
Main article: Paint Codes
The E30 was offered in a number of colours during its lifetime, in both solid and metallic paint. Some are unique to early cars, others were only available to facelift models.
The colour of your car will be printed on a sticker on your front passenger suspension turret.
Windows
Windscreen
Door windows
Main article: Door windows
Quarterglass
Trim
Chrome and Shadowline
Front Grille
Badges
Body Kits
Main article: Body Kits
Maintenance
Problems
Rust
Main article: Rust
