Technical
Engines
Main article: Engines
We're also constantly updating our knowledge on the newer non-E30 engines, to help them fit into your engine bay. By far the most popular upgrade is the M50/M52 engine swap, as well as the S60 for those with cash to spare. But don't turn your nose up on the big old M30 engines; if they were good enough for Alpina, then they're good enough for you.
Main article: Drivetrain
Main article: Brakes
Main article: Suspension
Steering
Main article: Steering
If you find the current setup a little slow and its taking too many turns from lock to lock, you can fit quicker racks from either the Z3 or the E36 M3.
Body Styles and Fittings
Main article: Bodywork
The E30 came in
Electrical
Main article: Electrical
