M20
Revision as of 22:52, 12 November 2011 by Grrrmachine (talk | contribs)
Models
M20 Oil pump and sump gasket
Sump Gasket
The M20 block is a cast iron design with six cylinders bored out to make the various engine capacities from 2.0 to 2.7 litres. The block can be identified by checking the number stamped on ...
Bear in mind that although the M20 engine was also fitted to the E34, engines from that car have the dipstick located in the sump. However, an aperture exists on the block, ready to be tapped, and the sump fitted to E30s bolts straight on to relocate the dipstick to its normal position.
Crank Bolt
  • M20B20 - 130mm
  • M20B25 - 135mm
  • M20B27 - 130mm
  • M21D25 - 130mm
The 135mm rod weighs 640g.
M50 rods can also be fitted between M20 cranks and pistons, providing either a longer stroke (up to 145mm) or a lighter rod, allowing the engine to rev that much more freely. The M3 or 328i piston rod fitted to the M50/S50 engines are the same dimensions as M20B25 rods at 135mm, but weigh significantly less (540-575g).
M20 Pistons
Ø: 84 84 84 84 84 84 84
ÜH: 4.2 4.2 4.43 3.6 0.65
MT: -6.2 -5.1 1.1 -3.5 -2
Stroke: 75 75 75 81 81 81 81
Crank Pulley
Cam
Rocker Arms
Breather Hose
The M20 flywheel is a single mass wheel which keeps the engine spinning long after you take your foot off the throttle. It is also the flat surface to which the Clutch mates, ultimately transferring power from the engine to the Drivetrain. The edge of the flywheel is toothed. Known as the ring gear, it is what allows the starter motor to bite onto the engine to start it. The flywheel bots to a pulley at the end of the crank.
On early Jetronic engines, the flywheel also has lugs which are used by the crank position sender to detect engine speed. These earlier engines also have different ring gears, meaning a Jetronic flywheel needs a Jetronic starter motor.
It is very rare for M20 starter motors to fail. If you are having problems starting your car, it is recommended to look at the common problems of E30s before removing the starter motor.
Engine Mounts
Oil
Main article: Oil
Oil Cooler
On all models fitted with the M20B25 engine (325i and Convertible) there is an external oil cooler fitted, and mounted under the normal engine radiator. It receives cool air through vents in the front Valance. However, with modern semi-synthetic oils, the oil cooler is redundant.
Main article: Cooling
Water Pump
Main article: M20 Water Pumps
Thermostat
Expansion Tank
Fan
Rubber Hoses
All the elements of the cooling system are linked with a series of rubber hoses. The seven hoses that make up the cooling system are as follows:
  • Pump to thermostat hose: 11531287651
  • Thermostat to rad hose: 11531722216
  • Bottom rad hose: 11531718980
  • Thermostat to bottom rad hose: 11531718982
  • Thermostat to heater and expansion tank hose: 11531722743
  • Throttle body hose: 13541719966
  • Block to throttle body hose: 13541719967
  • Block to heater hose: 64211380527
Drain Plug
Not Starting
Oil Leaks
Cracked Head
Stroker Engines
Engine Management
Useful websites
See Also
Engines M21 M30
