M20
Sump Gasket
The M20 block is a cast iron design with six cylinders bored out to make the various engine capacities from 2.0 to 2.7 litres. The block can be identified by checking the number stamped on ...
Bear in mind that although the M20 engine was also fitted to the E34, engines from that car have the dipstick located in the sump. However, an aperture exists on the block, ready to be tapped, and the sump fitted to E30s bolts straight on to relocate the dipstick to its normal position.
While the block determines the maximum capacity for the engine, the crankshaft determines to a large extent the stroke of the engine, and therefore the actual capacity. Mounted to the bottom of the block, the crank holds the bottom of the piston rods and converts their up/down motion into rotary force known as torque.
http://www.metricmechanic.com/pdfs/metric-mechanic-m20-engine-booklet.pdf
MM Introduces the 2900 Engine Evolution of our MM Stroker M20 Engines In the early 90’s, we were selling 2.8 Liter (85mm x 81mm “Baby Six” engines. Later, the bore was increased 1mm which led to our current 2900 Sport Engine. To build this larger engine, we replaced the stock 75mm “i” crank with an 81mm Breaking the 3.0 Liter Barrier By 2000, we had developed the 3200 Sport Engine using the 89.6mm stock crankshaft. Several times in the past, we had stuffed our “Big Six” engines into the 320i and WOW! these 3200 engines felt like a Big Six in the 325i, without the nose heavy weight penalty. We were so impressed, that over the next 4 years, we developed an entirely new engine line Over the years we’ve heard a rumor that the cast iron ETA crankshaft was somehow inferior to the Forged Steel 524 Turbo Diesel Crank. BMW used cast iron cranks in the following engines. 320/6 - 71mm stroke 323i - 76mm stroke 325e - 81mm stroke 325i/E30 - 75mm stroke 325i/E36/E46 - 75mm stroke In our experience, the cast iron cranks used in Baby Six Engines are very reliable punctuated by the fact that we have never seen one break. However, we have seen 4 Diesel cranks break. Two that we found in salvage yard engines, were broken in the middle. The other two were fatigued from hard racing 81mm Stroke Crankshafts - 275 HP engines revving to 7500 rpms. After 65-75 hours running vigorously, they cracked at the back of the 6th rod throw. Diesels rattle and vibrate throughout their lives and the crankshafts take a beating. Naturally, before we install a 524 Turbo Diesel crank in an engine, we would check it for cracks. This can be done by lifting the crank off the ground and striking each one of the 12 counter weights with a large wrench (19 mm or larger). It should ring like a bell. If it doesn’t - check the rod journal nearest the dead counter weight and look for a crack. A dead ring indicates a junk crankshaft. Although we do use the Diesel Crank, it is rare. Out of every 100 2900 engines we build, 99 have “e” cast cranks and 1 a Diesel Crank, typically per the customer’s request. Nice advantages are that the “e” cast crank is readily available, far more economical, and it is 3.5 lbs. lighter - 50.5 lbs “e” vs. 54 lbs. for the Diesel. By using our lightweight pistons and limiting the engine output to 225 HP and 6750 rpm, I see no reason why anyone would see an “e” crank break. stroke “e” crankshaft as used in the ETA engine. These readily available cranks have proven to be very tough and durable and rarely show signs of wear. Also, they bolt readily into either the “e” or “i” block without creating clearancing issues with the rods. For the “do-it yourselfer”, this is welcome news! The 524 TD Crank vs. the ETA Crank - Debunking the Myth of larger displacement M20 engines. Using later cranks from E36, E39 and E46 BMW models, we’ve been able to adapt these cranks to the M20 blocks by making modifications to the crank and clearancing the block. The 84mm, 86mm and 89.6mm stroke crankshafts are forged steel and are used in our 3.0 to 3.2 liter Sport or Rally Engines. Metric Mechanic Development History of the M20 Engine These 3200 engines feel like one of our Big Six’s in a 325i, without the nose heavy weight penalty.
Piston Rings
Crank Pulley
Cam
Rocker Arms
Breather Hose
Engine Mounts
Oil
Oil is picked up by the oil pump and
Oil Cooler
Main article: Cooling
Not Starting
Oil Leaks
Stroker Engines
Engine Management
