Main article: Clutch
- Put the handbrake on full
- Select 2nd or 3nd gear
Manual
Four-Speed | Five-Speed | |||||
316 | 316 316i 318i | 318iS | 323i Sport | 323i 324td 325e | 325i Sport | |
1st | 3.76 | 3.72 | 3.72 | 3.76 | 3.83 | 3.35 |
2nd | 2.04 | 2.02 | 2.02 | 2.33 | 2.20 | 2.03 |
3rd | 1.32 | 1.32 | 1.61 | 1.32 | 1.40 | 1.36 |
4th | 1.00 | 1.00 | 1.00 | 1.23 | 1.00 | 1.00 |
5th | 0.81 | 0.80 | 1.00 | 0.81 | 0.81 | |
Reverse | 4.10 | 3.45 | 3.71 | 4.10 | 3.46 | 3.20 |
Getrag 242 | Getrag 240 or 242/5 | Getrag 240 | Getrag 245 | Getrag 260 | Getrag 260/5 |
- Getrag 240 - MN and BMV (M10 carbureted models), BMO, TBCU and BCX (M40 cars and some 318iS)
- Getrag 240 - BCO, BCP and BCT - 318iS and E34 518i (pre 1992 overdrive). These boxes are the longer units with the shorter prop.
- Getrag 240 - BMW, MB and BMT - 320i models.
- Getrag 242 - LF (316 M10 only), MD and BMU (318i M10)
- Getrag 242/5 - AY, AW or LG
- Getrag 245 - BJ
- Getrag 260 - NW, ANB or TNW
- Getrag 260/5 - TNN or HM
Automatic
Three-Speed | Four-Speed | ||
316 318i | 320i 323i | 325i | |
1st | 2.48 | 2.73 | 2.48 |
2nd | 1.48 | 1.56 | 1.48 |
3rd | 1.00 | 1.00 | 1.00 |
4th | 0.73 | 0.73 | |
Reverse | 2.09 | 2.09 | 2.09 |
ZF 3 HP 22 | ZF 4 HP 22 |
Selector
Propshaft
Manual | Automatic | |
316 318i (M10) | 1560mm? | 1480mm |
316i 318i (M40) | 1480mm | |
318iS | 1570mm | |
320i | 1526mm | 1337mm |
323i | 1468mm | 1337mm |
324td 325i | 1483mm | 1327mm |
Guibo
Bearing
Main article: Differentials
Output Flanges
Drive Shafts
Clutch Issues
Clutch problems manifest themselves in all sorts of ways, from incredibly low biting points to reluctant gear changes and kangarooing. Because most people think the clutch works through black magic, they always fear the worst.
Oil Leaks
Sloppy Gearstick
Auto to Manual
Short Shifter
