Motronic
Revision as of 19:18, 28 February 2015 by Grrrmachine (talk | contribs)
Bosch Motronic ECU
Operation
ECU Codes
0261 200 989 Motronic 316i
0261 200 175 Motronic 318i
0261 200 386 Motronic 318i
0261 200 387 Motronic 318i
0261 200 172 Motronic 320i and 325i 1987
0261 200 173 Motronic 320i and 325i Plastic bumper 9/87 onwards
0261 200 087 Motronic 320iS
Converting to Motronic 1.3
Chipping
The Motronic system can be 'chipped', which involves replacing the standard EPROM (Erasable Programmable Read Only Memory) chip with one containing a performance enhancing program or 'map' for improved driveability, throttle response, mpg, raised rev limit, etc. The flat spots are eliminated by removing the unnecessary parts in the standard program that are there to cater for low-grade fuels, high altitudes, etc. used in other parts of the world.
Remapping
Third Party Engine Management
