Remapping Motronic
For those cars whose engine management system is Motronic 1.3, it is possible to wipe the chip in the ECU and recode it for custom performance. This is known as Remapping.
Inside your ECU is a chip, known as an EPROM (Erasable Programmable Read Only Memory). With the aid of an ultra-violet eraser and a programmer, it is possible to blank your chip and write your own map to govern fuelling and ignition timing.
Programming Langauge
Assembly Language:
MOV F0h,0Ah JNB F0h,51h DJNZ 08h,4Eh MOV A,09h CJNE A,#00h,24h ORL C1h,#C0h CLR AFh CLR 93h MOV C6h,A SETB AFh ANL C1h,#3Fh MOV A,#F4h ADD A,C6h MOV C6h,A MOV A,#01h ADDC A,C7h MOV C7h,A ORL C1h,#80h SETB 93h
Hexadecimal Language:
