[[Image:Drivetrain.jpg|thumb|600px|right|Drivetrain comprising gearbox, propshaft, differential, clutch, selector and pedal box.
Main article: Clutch
  • Put the handbrake on full
  • Select 2nd or 3nd gear
  • Give the engine plenty of revs
  • Now gently release the clutch pedal, giving more throttle as the clutch bites.
  • If your handbrake works well then you should be able to stall the engine. If you can get the clutch all the way up with the engine still revving then the clutch requires maintenance.
Manual
Manual Gearboxes
Four-Speed Five-Speed
316
318i
316 316i 318i
320i 324d
318iS 323i Sport 323i 324td 325e
325i 325iX
325i Sport
1st 3.76 3.72 3.72 3.76 3.83 3.35
2nd 2.04 2.02 2.02 2.33 2.20 2.03
3rd 1.32 1.32 1.61 1.32 1.40 1.36
4th 1.00 1.00 1.00 1.23 1.00 1.00
5th 0.81 0.80 1.00 0.81 0.81
Reverse 4.10 3.45 3.71 4.10 3.46 3.20
Getrag 242 Getrag 240 or 242/5 Getrag 240 Getrag 245 Getrag 260 Getrag 260/5
  • Getrag 240 - MN and BMV (M10 carbureted models), BMO, TBCU and BCX (M40 cars and some 318iS)
  • Getrag 240 - BCO, BCPand BCT - 318iS and E34 518i (pre 1992 overdrive). These boxes are the longer units with the shorter prop.
  • Getrag 242 - LF (316 M10 only), MD and BMU (318i M10)
  • Getrag 242/5 - AY, AW or LG
  • Getrag 245 - BJ
  • Getrag 260 - NW, ANB or TNW
  • Getrag 260/5 - TNN or HM
Automatic
Automatic Gearboxes
Three-Speed Four-Speed
316 318i 320i 323i 325i
1st 2.48 2.73 2.48
2nd 1.48 1.56 1.48
3rd 1.00 1.00 1.00
4th 0.73 0.73
Reverse 2.09 2.09 2.09
ZF 3 HP 22 ZF 4 HP 22
Selector
Gear stick and shifter rod
Propshaft
Propshaft centre joint and bearing, with collar nut highlighted
Manual Automatic
316 318i
318iS 1570mm
320i 1526mm 1337mm
323i 1468mm 1337mm
324td 325i 1483mm 1327mm
Guibo
Bearing
Main article: Differentials
Output Flanges
Output flange and drive shaft
Drive Shafts
Clutch Issues
Clutch problems manifest themselves in all sorts of ways, from incredibly low biting points to reluctant gear changes and kangarooing. Because most people think the clutch works through black magic, they always fear the worst.
Oil Leaks
Sloppy Gearstick
Auto to Manual
Short Shifter
