Engine Swap - M20
There's no simpler swap from the possible choice of engines than the mighty M20. While the smallest version was 2.0 litres, its full-fat form is a 2.5 litre version, which is the only one worth having. Around town it gives all the smoothness you'd expect from a straight six, and there's plenty of grunt so you won't be chasing up and down the gears trying to find the right cruising speed. But let her rip, and she'll provide as much tail-happy sliding as you want.
The M20 can be fitted to any E30, no matter whether it started life as an M10, M40 or M42. With the right base vehicle a weekend is enough to get everything bolted in and ready to go. You can even use this guide replace your existing M20 with a bigger version, and in that case the engines can be swapped over in a matter of hours.
This swap is considered the easiest swap because all the parts are standard BMW. There's no need for custom components, and everything you need can be supplied by one donor vehicle. In terms of fabrication, you may need to mount (weld) a few brackets under the bonnet for engine ancillaries and modify the loom a little, but this is specific to the age of your E30. We'll explain that later.
Parts List
For all swaps, you will need:
- Full engine with all ancillaries (injectors, AFM, coil, alternator, engine mounts, starter motor and flywheel)
- Complete engine loom
- ECU
- Complete exhaust from manifold to back box
- M20 Cooling system of radiator, hoses and expansion tank
- New rubber engine and gearbox mounts
- M20 Gearbox.
Engine
While parts suppliers do list differences between B20 and B25 engines, there's no practical difference. A B20 clutch will work fine on a B25 engine.
Prop
- 3.91 - Spirited driving, but quite high revs at motorway speeds which can be tiring and noisy
- 3.73 - Good all-rounder
- 3.64 - The cruising ratio, which helps claw back valuable fuel economy from the thirsty M20 engine.
The C101 plug on your loom is probably the trickiest part of the installation, as it's the main point for your engine loom to connect to the rest of the car. The C101 changed its shape during the 1987 facelift. Therefore, if your car is from before 1987 and your engine is newer, you're going to have to chop things up to get things to fit together. This can be done in three ways:
- Cutting off both C101 connectors and joining the wires directly. Simple, but means you can never unplug the engine loom again
- Convert the engine loom end
- Convert the car loom end
It doesn't really matter which system you fit to your engine as long as the pump matches, but the facelift setup is a slightly simpler install with newer components.
Exhaust
Brackets
- propshaft
- gear shifter linkage
- rear light switch cable
- throttle cable
- coil
- ECU
