M40
The M40 engine was released in 1987, and marked BMW's next generation of four-cylinder engines since the M10. It featured a belt-driven 8-valve OHC design, with an aluminium head on a cast iron block, and was produced in two capacities - The M40B16 of 1.6 litres, and the M40B18 of 1.8 litres. The only internal difference of these two versions was the crankshaft which modified the stroke and therefore overall displacement of the engine.
The E30 was equipped with both versions, powering the 316i and 318i respectively, and continued to use those engines until the end of production in 1994. Both were available with or without a catalyzer.
The M40 formed the basis of all BMW's four-cylinder engines over the next decade. While its direct successor was the M43, it also spawned the 16-valve M42 used in the 318iS, which shares many compatible components.
| M40B16 | 1.6 L (1596 cc/97 in³) | 75 kW (101 hp) @ 5500 | 143 N·m (105 ft·lbf) @ 4250 | 6200 | 1988 |
| 73 kW (98 hp) @ 5500 | 141 N·m (104 ft·lbf) @ 4250 | 6200 | 1988 | ||
| M40B18 | 1.8 L (1796 cc/109 in³) | 85 kW (114 hp) @ 5500 | 165 N·m (122 ft·lbf) @ 4250 | 6200 | 1987 |
| 83 kW (111 hp) @ 5500 | 162 N·m (119 ft·lbf) @ 4250 | 6200 | 1987 |
Sump Gasket
A single block design was used for all M40 engines, and they are completely interchangeable between models.
It is this distance that differentiates the two crankshafts fitted to M40 engines. The sizes are:
| M40B16 8.2:1 | M40B18 9.5:1 | |
| 87-94 | ||
| Ø: | 84 | |
| KH: | 36.15 | |
| MT: | 2.75 | |
| GL: | 63.5 | |
| BO: | 22.0 x 54 | |
| Stroke: | 72 | 81 |
| Conrod Length: | 140 | 140 |
| Volume | 1596cc | 1766cc |
| Piston Shape: | ||
Crank Pulley
Despite the three styles of Head, the rocker cover is interchangeable across all M40 engines. It is positioned on 8 studs and fixed with M10 nuts. It has one hole for the Oil Cap, and one port for the breather hose.
Cam
Rocker Arms
Breather Hose
Engine Mounts
Won't Rev Over 5000
To confirm, remove the rocker cover and baffle plate so that you have access to the cam shaft, and run your finger nail over the cam lobes. If you can feel scatches, grooves or other imperfections, the cam is in bad condition.
The only solution is to replace.
