M42
In E30 form it's twin cam 16v 4cyl 1796cc engine. It is an aluminium alloy engine which shares a development history with the M1, M5 and M635CSi engines.
The M42 is the last chain-driven engine fitted to the E30, and the first 16-valve unit. It featured a number of innovations that made it a far more modern engine than any other fitted to the E30, including a twin-valve throttle body, coil pack ignition and bi-concave combustion chambers. This made the 318iS both an economical and performance model, with good power and torque characteristics.
Engine | Displacement | Power | Torque | Redline | Year |
M42B18 | 1.8 L (1796 cc/110 in³) | 101 kW (136 hp) @ 6000 | 175 N·m (129 ft·lbf) @ 4500 | 6300 | 1989-96 |
100 kW (134 hp) @ 5500 | 172 N·m (127 ft·lbf) @ 4500 | 6300 | 1989-96 |
E36 Differences
If you have bought an E36 lump, you will need to swap the following components to E30-specific parts to fit your car:
The M42 Sump is a two part design with an upper and lower sump. The upper part bolts directly to the block, sealed with a gasket, and the lower sump then bolts to the upper using twenty 10mm nuts.
Sump Gasket
The iron block is bored to 84mm. The cylinders have a maximum ovality of: 0.01mm/0.0004" with an identical maximum taper. Compression pressures : 10-11bar (143-156psi):
Firing order: 1-3-4-2
The engine has hydraulic tappets which reduce the maintenance of the engine.
Cams
Being a 16V engine, the M42 head features two camshafts; an Intake and an Exhaust.
Lobe height: 1.8755-1.8803"
Rocker Arms
Timing Chain
Breather Hose
Intake Manifold
The inlet manifold is a two pieces design aimed at improving the low down torque of the engine.
Throttle Body
Engine Mounts
Torques
Nm | ft-lbs | |
Big ends - Step 1 | 23 | 17 |
Big ends - Step 2 | +70 degrees | |
Camshaft sprocket | 13-17 | 10-12 |
Camshaft bearing cap bolts | 13-17 | 10-12 |
Crankshaft damper | 300-320 | 217-231 |
Cylinder head Step 1 | 30-35 | 22-25 |
Cylinder head Step 2 | +90-95 degrees | |
Cylinder head Step 3 | +90-95 degrees | |
Exhaust manifold | 22-24 | 17-18 |
Flywheel | 82-94 | |
Intake manifold | 13-17 | 10-12 |
Main bearings Step 1 | 20-25 | 14-18 |
Main bearings Step 2 | +47-53 degree turn | |
Viscous fan coupling (LH threads) | 40-50 | 29-36 |
Timing chain tensioner: | 23-27 | 17-19 |
Profile Gasket
Part | Qty | Part Number | Part | Qty | Part Number | |
Gasket | 1 | 111 217 215 46 | Gasket | 1 | 116 117 344 90 | |
Bolt set | 1 | 111 217 219 39 | Nut | 4 | 183 017 377 74 | |
Valve cover | 1 | 111 217 218 76 | Valve cover | 3 | 111 217 214 75 | |
Gasket | 1 | 111 412 478 49 | Gasket | 1 | 115 317 211 72 | |
Gasket | 1 | 111 412 478 37 | Gasket | 1 | 116 117 346 84 | |
O-ring | 1 | 121 417 272 20 | O-ring | 1 | 115 317 212 18 | |
Seal ring | 1 | 071 199 633 55 | Throttle-b | 2 | 135 412 474 00 | |
Gasket | 1 | 183 017 119 69 | Gasket set | 1 | 111 417 219 19 | |
Antifreeze | 1 | 821 414 677 04 |
Timing Chain Tensioner
Tapping/ticking noise
Fuel smell
Lumpy idle
Loose Sump Bolts
Coil On Plug
Throttle Body Heater Delete
M20 Flywheel
Not all M42's came with dual mass fly wheels which is a common misconception. A cheaper and more road freindly alternative to an aluminium flywheel is to fit an M20 flywheel and clutch assembly.
Chips
Stroker Engines
