Fuel
This article primarily focuses on Motronic fuelling. For earlier fuel systems, learn more about Jetronic.
The M10 engine was also available in a fuel-injected version, but the base model 316 used a more traditional carburettor setup, with ignition controlled by a mechanical distributor.
Fuel Tank
The E30 range benefited from two different fuel tanks; a 55L and 63L. Tourings and facelift M20-engined cars will have the larger tank.
The 63 litre tank has a much more sophisticated internal syphon system to transfer fuel from the Left side to the right, which results in the levels in the two halves not being the same. For this reason, the 63 litre tank has a sensor in each half, connected in series, to give an average level for the fuel gauge.
Filler Pipe
To check the filler pipe for leaks, lift the rear o/s wheel and slide under the car. Locate the filler pipe coming from the rear wing. Grab the joining rubber pipe to the tank stub and pull it downwards.
Either the rubber pipe will pull off or fall apart, or you will see the filler stub on the tank move on it's brazed join to the tank. The rubber pipe can be replaced cheaply, but if the filler stub moves then the entire tank will have to be replaced.
Fuel Pump
Because of the two types of tank, there are two types of pump housing. A 55L pump housing will have two pipes on it, while a 63L pump housing will have only one.
A two-pipe housing can be used on a 63 litre tank, provided the second pipe is blanked off, and the pipe that was connected to it re routed to a stub pipe on the side of the 63 litre tank. If this pipe is not re-routed, you will only be able to use the fuel in the RH side.
Fuel Level Senders
While all pumps are equipped with a level sender, 63L tanks contain a second level sender on the left side of the tank, wired in series with the first. The construction of each sender is a basic float, which bridges two lengths of resistive wire. When the float is at the top, the wires are bridged close to their terminals, and thus read a low resistance. As the fuel level drops, so does the float, moving the bridge down the wires and thus increasing the resistance. In this way, each level sender works as a 60 Ohm resistor, reading zero Ohms for a full tank and 60 Ohms when empty.
Therefore the gauge for a 55 litre tank needs to read empty when in series with 60 ohms, but for a 63 litre tank gauge, it must read zero when in series with 120 ohms. Both need to read full when in series with zero ohms. This is why there are two types of fuel gauge available for the E30.
A 63 litre tank can be used with just a single level sensor, but the indicated level will vary, depending on the respective levels in the two halves.
If the gauge is still jumping around with both senders shorted out, then the brass nut on the back of the gauge, or the wiring (unlikely), is at fault.
Fuel Filter
Fuel Lines
Fuel Hoses
Fuel Rail
Injectors
The injectors are the exit point of the fuelling system. They are electrically-operated solenoids which, when activated, squirt fuel at such high pressures that it atomises into a fine mist, which is the most efficient form for it to burn.
Injectors do not need to be upgraded, and there is no benefit in fitting bigger injectors to a standard E30 engine. Many people believe that M50 injectors are an upgrade; they can be, but only if the rest of the engine has been substantially modified already and remapped accordingly. Fitting bigger engines alone will only result in rich running, causing damage to your engine in the long run.
Fuel Pressure Regulator
Carburettor
The lowliest model, the 316, was kitted out with the same carburettor technology that had seen service in the E21, based around the Pierburg 2BE carburettor. While massively advanced at the time, these carbs have since proved to be unreliable to the point of hateful, and almost any fuelling the 316 suffers from can be traced back to the Pierburg unit.
A proven solution is to replace the entire setup with an equivalent carburettor from Weber. Learn more about Weber carburettors.
Carbon Canister
Controlling
Fuel Pump Relay
No Fuel to Engine
- De-pressurise the system by removing Fuse 11 and cranking the engine
- Locate the thick rubber hoses leading to the FPR or fuel rail
- Undo the jubilee clip to the nearest accessible hose, pull the hose off and put the end into a securely-placed container
- Replace Fuse 11
- Crank the engine for a few seconds
- Check the bottle
- Check Fuse 11
- Identify and remove the Fuel Pump Relay.
- With the relay removed, bridge pins 30 (red wire) and 87 (green/violet) to directly power the fuel pump. Turn on ignition, and check for fuel.
- If fuel is now present, the fault lies in the controlling system.
- If no fuel is present, remove the fuel filter and place a suitable fluid containter here. Crank engine. If fuel is now present, replace your fuel filter.
- If fuel is still not present, the fault lies with your fuel pump.
Fuel Smell (Inside)
Fuel Smell (Outside)
Fuel Leak
| Leak Location | Cause | Solution |
| Engine Bay | Perished fuel hoses | Replace hoses |
| Rear Passenger Arch | Fuel Filter | Replace |
| Rear Driver Arch | Rusty filler pipe | Grab the rubber joining pipe and pull. If the stub pipe moves, replace fuel tank. |
Rich Running
Flooding
Cold Start
Hot Start
None at this time.
Diesel
- Main article: Diesel
