Revision as of 23:09, 4 February 2012 by Grrrmachine (talk | contribs)
Everything that connects the Wheels to the Bodywork of your E30 is the Suspension. This arrangement of springs, shocks and arms is responsible for keeping the rubber of your tyres on the road at all times; without it, you'd be bounced around a pinball.
Front
Front suspension layout
The front suspension is comprised of two struts which each incorporate a shock absorber and a spring. At the lower end of the strut, the stub axles carry the wheel hub via a wheel bearing. The top of the shock absorber screws to the upper strut mount, which bolts directly to the vehicle bodywork. Between the two ends of the shock absorber, two metal plates squeeze together the spring, which is the main reaction element of the spring.
Struts
Struts come in two sizes: 45mm and 51mm. The bigger size was standard on all 325i models, all Tourings and all Cabriolets. If you are unsure of what size strut your car has, and you can't remember your maths lessons, then use a bit of string. Wrap the string around the strut, and then measure its length; 141mm means a 45mm strut, and 160mm means a 51mm strut.
Shocks
Top Mount
Bump Stop
Springs
The springs are fat coils of steel that compress under force, allowing the entire front suspension to react to the road conditions. There are a wide variety of springs available for the E30, and they are the single biggest factor when contemplating changes to your suspension setup. In terms of compatibility, the spring must be matched to the size of the strut.
The springs themselves are sandwiched between two plates. The lower plate is an integral part of the strut, cupping the bottom of the spring. At the top end, a moving spring plate is sandwiched under the bump stop and top mount. There are also two rubber pads, known as spring rubbers, which prevent the springs rusting onto the plates.
Stub Axle
Wheel Hub
Wheel Bearing
To remove a wheel bearing:
  3. Remove the 36mm nut
Subframe
Wishbones
Lollipops
Ball Joints
Anti-Roll Bar
Main article: Anti-Roll Bar
Rear
Rear suspension layout
Rear Beam
Trailing Arms
Rear Wheel Hubs
Rear Wheel Bearings
The OEM manufacturer of these bearings is FAG.
Rear Shocks
Rear Top Mounts
Rear Springs
The rear springs are a much smaller type than their front counterparts, comprising a squatter, fatter profile. They sit on special plates welded to the trailing arms and bodywork, cushioned with rubber pads known as top hats.
Rear Anti-Roll Bar
The ARB itself is mounted to the body using steel shells and rubber bushes. The two ends then curve down where they slot into drop links. These rubber-bushed arms then bolt directly to the trailing arm. To remove or fit a rear ARB is relatively easy, and does not require the dismantling of any other suspension components; it just requires a certain patience to thread the bar sideways and into place.
Inner Tyre Wear
Maintenance
Bush Renovation
Bigger Struts
Better Shocks and Springs
Coilovers
Lowering
As a simple guideline, 30mm is considered reasonable, while 60mm is the safest maximum level. That's not to stop others lowering their cars by 80mm or more, but for the design of the E30 it is not recommended.
Strut Brace
