M5x
Revision as of 22:07, 16 November 2011 by Grrrmachine (talk | contribs)
M50
Engine Displacement Power Torque Redline Bore Stroke Year
M50B20 2.0 L (1990 cc/121 in³) 110 kW (150 hp) @ 6000 190 N·m (140 ft·lbf) @ 4700 6750 80mm 66mm 1991
M50B25 2.5 L (2494 cc/152 in³) 141 kW (192 hp) @ 6000 245 N·m (181 ft·lbf) @ 4700 6500 84mm 75mm 1991
M50TU
M50TUB20 2.0 L (1990 cc/121 in³) 110 kW (150 hp) @ 5900 190 N·m (140 ft·lbf) @ 4700 6750 80mm 66mm 1993
M50TUB25 2.5 L (2494 cc/152 in³) 141 kW (192 hp) @ 5900 250 N·m (184 ft·lbf) @ 4200 6500 84mm 75mm 1993
M52
The M52 brought two new things to the BMW range of engines. Dual-VANOS, and Nikasil.
M52B20 2.0 L (1990 cc/121 in³) 110 kW (148 hp) @ 5900 190 N·m (140 ft·lbf) @ 4700 6500 80mm 66mm 1994
M52B25 2.5 L (2494 cc/152 in³) 123 kW (170 hp) @ 5500 245 N·m (181 ft·lbf) @ 3950 6500 84mm 75mm 1995
M52B28 2.8 L (2793 cc/170 in³) 142 kW (193 hp) @ 5300 280 N·m (207 ft·lbf) @ 3950 6500 84mm 84mm 1995
M52TU
S50
S50B30 3.0 L (2990 cc/182 in³) 210 kW (286 hp) @ 7000 320 N·m (235 ft·lbf) @ 3600 7280 86mm 85.8mm 1992
S50B32 3.2 L (3201 cc/195 in³) 236 kW (321 hp) @ 7400 350 N·m (257 ft·lbf) @ 3250 7600 86.4mm 91mm 1995
S52
Sump Gasket
Piston Head
Piston Rings
Crank Pulley
VANOS
Despite the three styles of Head, the rocker cover is interchangeable across all M40 engines. It is positioned on 8 studs and fixed with M10 nuts. It has one hole for the Oil Cap, and one port for the breather hose.
Cam
Rocker Arms
Breather Hose
Engine Mounts
Useful websites
See also
