M20
The M20 oil pump is a gear-driven unit that takes its power from the crank via an intermediate drive shaft. M20 oil pumps are usually very reliable, and only need to be replaced if you have smashed your sump somehow. To remove,
Sump Gasket
| M20B25 8.8:1 | M20B25 9.4:1 | M20B25 9.7:1 | M20B27 8.5:1 | M20B27 9.0:1 | M20B27 10.2:1 | M20B27 11.0:1 | |
| 87-90 (all with cat) | 87-88 (??) | 85-89 (Euro i) | 87-88 (USA super ETA) | 82-87 (USA) | 85-87 (Euro e) | 83-85 (Euro e) | |
| Ø: | 84 | 84 | 84 | 84 | 84 | 84 | 84 |
| KH: | 34.2 | 34.2 | 34.2 | 36.2 | 35.7 | 35.7 | 35.7 |
| ÜH: | 4.2 | 4.2 | 4.43 | 3.6 | 0.65 | ||
| VT: | -0.4/-1.5 | -0.4/-1.5 | -2.12/-2.22 | -1.2 | -0.9 | -1.2 | |
| MT: | -6.2 | -5.1 | 1.1 | -3.5 | -2 | ||
| GL: | 63.63 | 63.43 | 73.63 | 64.81 | 77.7 | 77.7 | 78.35 |
| BO: | 22.0 x 54 | 22.0 x 54 | 22.0 x 54 | 22.0 x 54 | 22.0 x 54 | 22.0 x 54 | 22.0 x 54 |
| Stroke: | 75 | 75 | 75 | 81 | 81 | 81 | 81 |
| Conrod Length: | 135 | 135 | 135 | 130 | 130 | 130 | 130 |
| Volume | 2493 | 2493 | 2493 | 2692 | 2692 | 2692 | 2692 |
| Deck | 206.7 | 206.7 | 206.7 | 206.7 | 206.2 | 206.2 | 206.2 |
| Piston Shape: | File:M20B25 8 8.gif | File:M20B25 9 4.gif | File:M20B25 9 7.gif | File:M20B27 8 5.gif | File:M20B27 9 0.gif | File:M20B27 10 2.gif | File:M20B27 11.gif |
Piston Rings
Crank Pulley
Cam
Rocker Arms
Breather Hose
Engine Mounts
Oil
Oil is picked up by the oil pump and
Oil Cooler
Main article: Cooling
Not Starting
Stroker Engines
Engine Management
