Body Kits
Body kits, also knows as an Aerodynamics Package, were plastic or fibreglass accessories that fitted to the extremities of the car. While their aerodynamic function is limited, they do provide aesthetic enhancements to the E30 body style.
Bodykits
AV3
Description Available as an aftermarket extra from Autovogue. Essentially a copy of the kit fitted to the E36 M3
Features Fitting Picture
Front Valance 140px
Rear Valance 140px
Breyton
Description Available as an aftermarket extra from Breyton
Hartge H23
Description Fitted to the pre-facelift Hartge model H23 and the 323i-powered H26
Hartge H26/H27
Description Fitted to the facelifted Hartge models; the 325i-powered H26 and the M30-powered H27
Racing Dynamics
Description Available as an aftermarket extra from Racing Dynamics
Front Valance 140px
Skirts 140px
Reiger GTS
Description Available as an aftermarket extra from Reiger
Front Valance Despite the reknown of Reiger as a company, these bodykits do not come with any form of mounting equipment. Reiger supply pop rivets and a tube of seam sealer. Dj.jpg
Tech 1
Description Fitted to the pre-facelift 325i Sport in 1987.
Front Bumper/Valance The Tech 1 bumper and valance are a one-piece unit. DSCF1016.jpg
Rear Bumper Unlike the front, the rear bumper is separate from its valance. DSCF1080.jpg
Rear Valance 140px
Tech 2
Description Fitted to the facelifted 325i Sport in 1988-1991.
Front Valance Unlike the Tech 1 valance, the Tech 2 has special holes which mount to plastic brake ducts. These carry air from the valance directly to the discs to aid cooling. Cimg2906p.jpg
Skirts 2-door and 4-door/Touring skirts are different as the 2-door sill covers have slots in the top of them for the rear quarter pod to slide into. The 4-door sill cover doesn't have these slots, and is therefore a different part number. Casp23.jpg
Rear Bumper/Valance The Tech 2 rear bumper and valance are a one-part component. Fitting Guide Cimg2848a.jpg
Zender
Description Available as an aftermarket extra from Zender
Front Valances
The valance is the metal panel running behind and underneath the bumper on E30s, and is the key distinguishing feature between pre- and facelift cars. Because of that re-design, all the major body kit manufacturers listed above ran two versions of their valances, to accommodate the differences.
The differing styles took into account mounting for fog lights, air flow to the brakes and oil cooling, and the concept of combined units that incorporated both a chin spoiler and bumper into one unit.
Name Fitted To Features Fitting Picture
Alpina Type 147 The early Alpina valance was fitted to the range of Alpina models running up to 1987. 86342407.jpg
Alpina Type 159 For plastic-bumpered Alpina cars with no A/C 189274 10150281743079208 690269207 7760863 4502437 n.jpg
BBS For pre-facelift vehicles. Has the earlier shape bumper mount holes, making it exclusive to early vehicles. BBSValance.jpg
Lips
Pre-facelift Lip All E30s up to 1987 140px
iS Lip Mounts using standard BMW clips along the bottom edge of the valance IMAG0176.jpg
"Jimmy Hill" BMW Optional Extra The affectionally-named BMW option, part number 1919743, is uniquely identifiable by its extreme protrusion from the valance, making this item much more a 'chin' than a 'lip'. 100 0991.jpg
Volvo Lip Volvo 740 Mounts using standard BMW clips along the bottom edge of the valance. The key, however, is to mount it upside-down. DSC 0206.jpg
Side Skirts
SE Skirts The Special Equipment sideskirts were fitted as standard to Touring and Cabriolet models, and were also found on all SE models of the 320i and 325i. Each skirt is in two pieces; a main section running under the doors to the rear arch, and a small leading section which covers the lower portion of the front wing. These two parts simply slide and clip together.
Fitting Guide 140px
140px
