Body kits, also knows as an Aerodynamics Package, were plastic or fibreglass accessories that fitted to the extremities of the car. While their aerodynamic function is limited, they do provide aesthetic enhancements to the E30 body style.
Bodykits
AV3
| Description
Available as an aftermarket extra from Autovogue. Essentially a copy of the kit fitted to the E36 M3
Features
| Front Valance
140px
| Skirts
| Rear Valance
140px
Breyton
| Description
Available as an aftermarket extra from Breyton
Features
| Front Valance
| Skirts
| Rear Valance
Hartge H23
| Description
Fitted to the pre-facelift Hartge model H23 and the 323i-powered H26
Features
| Front Valance
| Rear Valance
Hartge H26/H27
| Description
Fitted to the facelifted Hartge models; the 325i-powered H26 and the M30-powered H27
Features
| Front Valance
| Skirts
| Rear Valance
Racing Dynamics
| Description
Available as an aftermarket extra from Racing Dynamics
Features
| Front Valance
140px
| Skirts
140px
| Rear Valance
Reiger GTS
| Description
Available as an aftermarket extra from Reiger
Features
| Front Valance
Despite the reknown of Reiger as a company, these bodykits do not come with any form of mounting equipment. Reiger supply pop rivets and a tube of seam sealer.
| Skirts
| Rear Valance
Tech 1
| Description
Fitted to the pre-facelift 325i Sport in 1987.
Features
| Front Bumper/Valance
The Tech 1 bumper and valance are a one-piece unit.
| Skirts
| Rear Bumper
Unlike the front, the rear bumper is separate from its valance.
| Rear Valance
140px
| Spoiler
Tech 2
| Description
Fitted to the facelifted 325i Sport in 1988-1991.
Features
| Front Bumper
Fitting Guide
| Front Valance
Unlike the Tech 1 valance, the Tech 2 has special holes which mount to plastic brake ducts. These carry air from the valance directly to the discs to aid cooling.
| Skirts
2-door and 4-door/Touring skirts are different as the 2-door sill covers have slots in the top of them for the rear quarter pod to slide into. The 4-door sill cover doesn't have these slots, and is therefore a different part number.
| Rear Bumper/Valance
The Tech 2 rear bumper and valance are a one-part component.
Fitting Guide
Zender
| Description
Available as an aftermarket extra from Zender
Features
| Front Valance
| Skirts
| Rear Valance
Front Valances
The valance is the metal panel running behind and underneath the bumper on E30s, and is the key distinguishing feature between pre- and facelift cars. Because of that re-design, all the major body kit manufacturers listed above ran two versions of their valances, to accommodate the differences.
The differing styles took into account mounting for fog lights, air flow to the brakes and oil cooling, and the concept of combined units that incorporated both a chin spoiler and bumper into one unit.
| Name
Fitted To
Features
| Alpina Type 147
The early Alpina valance was fitted to the range of Alpina models running up to 1987.
| Alpina Type 159
For plastic-bumpered Alpina cars with no A/C
| BBS
For pre-facelift vehicles.
Has the earlier shape bumper mount holes, making it exclusive to early vehicles.
Lips
| Name
Fitted To
Features
| Pre-facelift Lip
All E30s up to 1987
140px
| Facelift Lip
All standard E30s from 1987
| iS Lip
Mounts using standard BMW clips along the bottom edge of the valance
| "Jimmy Hill"
BMW Optional Extra
The affectionally-named BMW option, part number 1919743, is uniquely identifiable by its extreme protrusion from the valance, making this item much more a 'chin' than a 'lip'.
| Volvo Lip
Volvo 740
Mounts using standard BMW clips along the bottom edge of the valance. The key, however, is to mount it upside-down.
Side Skirts
| Name
Fitted To
Features
| SE Skirts
The Special Equipment sideskirts were fitted as standard to Touring and Cabriolet models, and were also found on all SE models of the 320i and 325i.
Each skirt is in two pieces; a main section running under the doors to the rear arch, and a small leading section which covers the lower portion of the front wing. These two parts simply slide and clip together.
Fitting Guide
140px
140px
