M5x
M50
Engine | Displacement | Power | Torque | Redline | Bore | Stroke | Year |
M50B20 | 2.0 L (1990 cc/121 in³) | 110 kW (150 hp) @ 6000 | 190 N·m (140 ft·lbf) @ 4700 | 6750 | 80mm | 66mm | 1991 |
M50B25 | 2.5 L (2494 cc/152 in³) | 141 kW (192 hp) @ 6000 | 245 N·m (181 ft·lbf) @ 4700 | 6500 | 84mm | 75mm | 1991 |
M50TU
M50TUB20 | 2.0 L (1990 cc/121 in³) | 110 kW (150 hp) @ 5900 | 190 N·m (140 ft·lbf) @ 4700 | 6750 | 80mm | 66mm | 1993 |
M50TUB25 | 2.5 L (2494 cc/152 in³) | 141 kW (192 hp) @ 5900 | 250 N·m (184 ft·lbf) @ 4200 | 6500 | 84mm | 75mm | 1993 |
M52
The M52 brought two new things to the BMW range of engines. Dual-VANOS, and Nikasil.
M52B20 | 2.0 L (1990 cc/121 in³) | 110 kW (148 hp) @ 5900 | 190 N·m (140 ft·lbf) @ 4700 | 6500 | 80mm | 66mm | 1994 |
M52B25 | 2.5 L (2494 cc/152 in³) | 123 kW (170 hp) @ 5500 | 245 N·m (181 ft·lbf) @ 3950 | 6500 | 84mm | 75mm | 1995 |
M52B28 | 2.8 L (2793 cc/170 in³) | 142 kW (193 hp) @ 5300 | 280 N·m (207 ft·lbf) @ 3950 | 6500 | 84mm | 84mm | 1995 |
M52TU
S50
S50B30 | 3.0 L (2990 cc/182 in³) | 210 kW (286 hp) @ 7000 | 320 N·m (235 ft·lbf) @ 3600 | 7280 | 86mm | 85.8mm | 1992 |
S50B32 | 3.2 L (3201 cc/195 in³) | 236 kW (321 hp) @ 7400 | 350 N·m (257 ft·lbf) @ 3250 | 7600 | 86.4mm | 91mm | 1995 |
S52
Sump Gasket
Piston Head
Piston Rings
Crank Pulley
VANOS
Despite the three styles of Head, the rocker cover is interchangeable across all M40 engines. It is positioned on 8 studs and fixed with M10 nuts. It has one hole for the Oil Cap, and one port for the breather hose.
Cam
Rocker Arms
Breather Hose
Engine Mounts
