Body Kits
Revision as of 18:40, 13 November 2011 by Grrrmachine (talk | contribs)
Body kits, also knows as an Aerodynamics Package, were plastic or fibreglass accessories that fitted to the extremities of the car. While their aerodynamic function is limited, they do provide aesthetic enhancements to the E30 body style.
Bodykits
AV3
Description Available as an aftermarket extra from Autovogue. Essentially a copy of the kit fitted to the E36 M3
Features Fitting Picture
Front Valance 140px
Rear Valance 140px
Breyton
Description Available as an aftermarket extra from Breyton
Front Valance 140px
Skirts 140px
Rear Valance 140px
Hartge H23
Description Fitted to the pre-facelift Hartge model H23 and the 323i-powered H26
Hartge H26/H27
Description Fitted to the facelifted Hartge models; the 325i-powered H26 and the M30-powered H27
Racing Dynamics
Description Available as an aftermarket extra from Racing Dynamics
Front Valance 140px
Skirts 140px
Reiger GTS
Description Available as an aftermarket extra from Reiger
Front Valance Despite the reknown of Reiger as a company, these bodykits do not come with any form of mounting equipment. Reiger supply pop rivets and a tube of seam sealer. Dj.jpg
Tech 1
Description Fitted to the pre-facelift 325i Sport in 1987.
Front Bumper/Valance The Tech 1 bumper and valance are a one-piece unit. DSCF1016.jpg
Rear Bumper Unlike the front, the rear bumper is separate from its valance. DSCF1080.jpg
Rear Valance 140px
Tech 2
Description Fitted to the facelifted 325i Sport in 1988-1991.
Front Valance Unlike the Tech 1 valance, the Tech 2 has special holes which mount to plastic brake ducts. These carry air from the valance directly to the discs to aid cooling. Cimg2906p.jpg
Skirts 2-door and 4-door/Touring skirts are different as the 2-door sill covers have slots in the top of them for the rear quarter pod to slide into. The 4-door sill cover doesn't have these slots, and is therefore a different part number. Casp23.jpg
Rear Bumper/Valance The Tech 2 rear bumper and valance are a one-part component. Fitting Guide Cimg2848a.jpg
Zender
Description Available as an aftermarket extra from Zender
Front Valance 140px
Skirts 140px
Rear Valance 140px
Lips
Name Fitted To Features Fitting Picture
Pre-facelift Lip All E30s up to 1987 140px
Facelift Lip All standard E30s from 1987 140px
iS Lip Mounts using standard BMW clips along the bottom edge of the valance 140px
Volvo Lip Volvo 740 Mounts using standard BMW clips along the bottom edge of the valance. The key, however, is to mount it upside-down. DSC 0206.jpg
Side Skirts
SE Skirts The Special Equipment sideskirts were fitted as standard to Touring and Cabriolet models, and were also found on all SE models of the 320i and 325i. Each skirt is in two pieces; a main section running under the doors to the rear arch, and a small leading section which covers the lower portion of the front wing. These two parts simply slide and clip together.
Fitting Guide 140px
140px
