Body Kits
Body kits, also knows as an Aerodynamics Package, were plastic or fibreglass accessories that fitted to the extremities of the car. While their aerodynamic function is limited, they do provide aesthetic enhancements to the E30 body style.
Bodykits
Hartge H26/H27
| Description | Fitted to the facelifted Hartge models, H26 and H27 | ||
| Features | Fitting | Picture | |
| Front Valance | |||
| Skirts | |||
| Rear Valance | |||
Tech 2
| Description | Fitted to the facelifted 325i Sport in 1988-1991. | ||
| Front Bumper | Fitting Guide | ||
| Front Valance | Unlike the Tech 1 valance, the Tech 2 has special holes which mount to plastic brake ducts. These carry air from the valance directly to the discs to aid cooling. | ||
| Skirts | 2-door and 4-door/Touring skirts are different as the 2-door sill covers have slots in the top of them for the rear quarter pod to slide into. The 4-door sill cover doesn't have these slots, and is therefore a different part number. | ||
| Rear Bumper | |||
| Rear Valance | |||
Lips
| Name | Fitted To | Features | Fitting | Picture |
| Pre-facelift Lip | ||||
| Facelift Lip | ||||
| iS Lip | ||||
| Volvo Lip |
Side Skirts
| SE Skirts | The Special Equipment sideskirts were fitted as standard to Touring and Cabriolet models, and were also found on all SE models of the 320i and 325i. | Each skirt is in two pieces; a main section running under the doors to the rear arch, and a small leading section which covers the lower portion of the front wing. These two parts simply slide and clip together.
The kit is mounted using a series of plastic clips. Along the top edge, these clips plug into holes drilled into the sill, while the bottom edge clips directly to the lower sill edge. As the skirt tucks into the wheel arch at both ends, two more holes are drilled into the wheel arch lip to hold plastic plugs. |
Fitting Guide | |
