Main article: Clutch
- Put the handbrake on full
 - Select 2nd or 3nd gear
Manual
- Getrag 240 - MN and BMV (M10 carbureted models), BMO, TBCU and BCX (M40 cars and some 318iS)
 - Getrag 240 - BCO, BCP and BCT - 318iS and E34 518i (pre 1992 overdrive). These boxes are the longer units with the shorter prop.
 - Getrag 240 - BMS, MB and BMT - 320i models.
 - Getrag 242 - LF (316 M10 only), MD and BMU (318i M10)
 - Getrag 242/5 - AY, AW or LG
 - Getrag 245 - BJ
 - Getrag 260 - NW, ANB or TNW
 - Getrag 260/5 - TNN or HM
Automatic
| 1st | 2.48 | 2.73 | 2.48 |
| 2nd | 1.48 | 1.56 | 1.48 |
| 3rd | 1.00 | 1.00 | 1.00 |
| 4th | 0.73 | 0.73 | |
Selector
Propshaft
| Manual | Automatic | |
| 316 318i (M10) | 1560mm? | 1480mm |
| 316i 318i (M40) | 1480mm | |
| 318iS | 1570mm | |
| 320i | 1526mm | 1337mm |
| 323i | 1468mm | 1337mm |
Guibo
Bearing
Main article: Differentials
Output Flanges
Drive Shafts
Clutch Issues
Clutch problems manifest themselves in all sorts of ways, from incredibly low biting points to reluctant gear changes and kangarooing. Because most people think the clutch works through black magic, they always fear the worst.
Oil Leaks
Sloppy Gearstick
Auto to Manual
Short Shifter
