Engine Swap - M20
Revision as of 20:50, 20 February 2013 by Grrrmachine (talk | contribs)
There's no simpler swap from the possible choice of engines than the mighty M20. While the smallest version was 2.0 litres, its full-fat form is a 2.5 litre version, which is the only one worth having. Around town it gives all the smoothness you'd expect from a straight six, and there's plenty of grunt so you won't be chasing up and down the gears trying to find the right cruising speed. But let her rip, and she'll provide as much tail-happy sliding as you want.
The M20 can be fitted to any E30, no matter whether it started life as an M10, M40 or M42. With the right base vehicle a weekend is enough to get everything bolted in and ready to go. You can even use this guide replace your existing M20 with a bigger version, and in that case the engines can be swapped over in a matter of hours.
This swap is considered the easiest swap because all the parts are standard BMW. There's no need for custom components, and everything you need can be supplied by one donor vehicle. In terms of fabrication, you may need to mount (weld) a few brackets under the bonnet for engine ancillaries and modify the loom a little, but this is specific to the age of your E30. We'll explain that later.
Parts List
For all swaps, you will need:
  • Full engine with all ancillaries (injectors, AFM, coil, alternator, engine mounts, starter motor and flywheel)
  • Complete engine loom
  • ECU
  • Complete exhaust from manifold to back box
  • M20 Cooling system of radiator, hoses and expansion tank
  • M20 Coding plug for the Instrument cluster
  • A mate on standby. An extra pair of hands can save your life.
Engine
While parts suppliers do list differences between B20 and B25 engines, there's no practical difference. A B20 clutch will work fine on a B25 engine.
Prop
  • 3.91 - Spirited driving, but quite high revs at motorway speeds which can be tiring and noisy
  • 3.73 - Good all-rounder
  • 3.64 - The cruising ratio, which helps claw back valuable fuel economy from the thirsty M20 engine.
The C101 plug on your loom
The ECU is a sealed box that contains the brain of your engine. Make sure you have the right one for your engine by comparing the part number against our list of ECUs. If you're struggling, you can fit an ECU from a 320i to your M20B25 engine; it'll just run weak. That can be fixed by fitting a chip, as long as you're running Motronic 1.3.
Exhaust
Brackets
  • propshaft
  • gear shifter linkage
  • rear light switch cable
  • throttle cable
  • coil
  • ECU
