Fuel
Revision as of 06:12, 10 April 2012 by Grrrmachine (talk | contribs)
The M10 engine was also available in a fuel-injected version, but the base model 316 used a more traditional carburettor setup, with ignition controlled by a mechanical distributor.
Fuel Tank
Filler Pipe
To check the filler pipe for leaks, lift the rear o/s wheel and slide under the car. Locate the filler pipe coming from the rear wing. Grab the joining rubber pipe to the tank stub and pull it downwards.
Either the rubber pipe will pull off or fall apart, or you will see the filler stub on the tank move on it's brazed join to the tank. The rubber pipe can be replaced cheaply, but if the filler stub moves then the entire tank will have to be replaced.
Fuel Pump
318i fuel pump (white plug) with sender (black plug)
Fuel Level Senders
If the gauge is still jumping around with both senders shorted out, then the brass nut on the back of the gauge, or the wiring (unlikely), is at fault.
Fuel Filter
Fuel Lines
Fuel Hoses
Fuel Rail
Injectors
The injectors are the exit point of the fuelling system. They are electrically-operated solenoids which, when activated, squirt fuel at such high pressures that it atomises into a fine mist, which is the most efficient form for it to burn.
Injectors do not need to be upgraded, and there is no benefit in fitting bigger injectors to a standard E30 engine. Many people believe that M50 injectors are an upgrade; they can be, but only if the rest of the engine has been substantially modified already and remapped accordingly. Fitting bigger engines alone will only result in rich running, causing damage to your engine in the long run.
Fuel Pressure Regulator
Carburettor
The lowliest model, the 316, was kitted out with the same carburettor technology that had seen service in the E21, based around the Pierburg 2BE carburettor. While massively advanced at the time, these carbs have since proved to be unreliable to the point of hateful, and almost any fuelling the 316 suffers from can be traced back to the Pierburg unit.
A proven solution is to replace the entire setup with an equivalent carburettor from Weber. Learn more about Weber carburettors.
Carbon Canister
Controlling
Fuel Pump Relay
No Fuel to Engine
  • De-pressurise the system by removing Fuse 11 and cranking the engine
  • Undo the jubilee clip to the nearest accessible hose, pull the hose off and put the end into a securely-placed container
  • Replace Fuse 11
  • Check the bottle
  • Check Fuse 11
Fuel Smell (Inside)
Fuel Smell (Outside)
Fuel Leak
Fuel Leaks
Leak Location Cause Solution
Rich Running
Flooding
Cold Start
Hot Start
None at this time.
Diesel
Main article: Diesel
