Motronic
Motronic ML1.0 was one of the first digital engine-management systems developed by Bosch. The basic idea behind the system was to fully integrate and regulate all major engine system parameters, thereby enabling fuel delivery and spark timing control functions to be controlled by the same unit, in an attempt to achieve optimum efficiency, driveability and power output potential. These early Motronic systems integrated the spark timing element with then-existing Jetronic fuel injection technology.
Operation
ECU Codes
Converting to Motronic 1.3
Chipping
The Motronic system can be 'chipped', which involves replacing the standard EPROM (Erasable Programmable Read Only Memory) chip with one containing a performance enhancing program or 'map' for improved driveability, throttle response, mpg, raised rev limit, etc. The flat spots are eliminated by removing the unnecessary parts in the standard program that are there to cater for low-grade fuels, high altitudes, etc. used in other parts of the world.
Remapping
Third Party Engine Management
