Motronic
Motronic ML1.0 was one of the first digital engine-management systems developed by Bosch. The basic idea behind the system was to fully integrate and regulate all major engine system parameters, thereby enabling fuel delivery and spark timing control functions to be controlled by the same unit, in an attempt to achieve optimum efficiency, driveability and power output potential. These early Motronic systems integrated the spark timing element with then-existing Jetronic fuel injection technology.
Operation
ECU Codes
ECU Number | System | Models | From/To |
0261 200 174 | Motronic | 316i | 1988 Onwards |
0261 200 989 | Motronic | 316i | |
0261 200 157 | Motronic | 318i | 1987 - 88 |
0261 200 175 | Motronic | 318i | |
0261 200 386 | Motronic | 318i | |
0261 200 387 | Motronic | 318i | |
0261 200 175 | Motronic | 318iS | 1989 onwards |
0261 200 172 | Motronic | 320i and 325i | 1987 |
0261 200 381 | Motronic | 320i | 1987 onwards |
0261 200 164 | Motronic | 325i Auto | 9/87 onwards |
0261 200 073 | Motronic | 325i Chrome bumper | 1985 - 87 |
0261 200 173 | Motronic | 320i and 325i Plastic bumper | 9/87 onwards |
0261 200 380 | Motronic | 325i | 8/88 onwards |
0261 200 071 | Motronic | Early 195/200bhp M3 and Evo 1 | |
0261 200 090 | Motronic | M3 Evo II | |
0261 200 091 | Motronic | M3 with 215bhp | |
0261 200 092 | Motronic | M3 Sport Evo | |
0261 200 042 | Motronic | 325e | until 9/85 |
0261 200 087 | Motronic | 320iS | |
0261 200 074 | Motronic | 325e | 9/85 onwards (Low compression) |
Converting to Motronic 1.3
Chipping
The Motronic system can be 'chipped', which involves replacing the standard EPROM (Erasable Programmable Read Only Memory) chip with one containing a performance enhancing program or 'map' for improved driveability, throttle response, mpg, raised rev limit, etc. The flat spots are eliminated by removing the unnecessary parts in the standard program that are there to cater for low-grade fuels, high altitudes, etc. used in other parts of the world.
Remapping
