Body Kits
Revision as of 15:48, 13 November 2011 by Grrrmachine (talk | contribs)
Body kits, also knows as an Aerodynamics Package, were plastic or fibreglass accessories that fitted to the extremities of the car. While their aerodynamic function is limited, they do provide aesthetic enhancements to the E30 body style.
Bodykits
Hartge H26/H27
Description Fitted to the facelifted Hartge models, H26 and H27
Features Fitting Picture
Reiger GSX
Description Available as an aftermarket extra from Reiger
Front Valance 140px
Tech 2
Description Fitted to the facelifted 325i Sport in 1988-1991.
Front Valance Unlike the Tech 1 valance, the Tech 2 has special holes which mount to plastic brake ducts. These carry air from the valance directly to the discs to aid cooling. Cimg2906p.jpg
Skirts 2-door and 4-door/Touring skirts are different as the 2-door sill covers have slots in the top of them for the rear quarter pod to slide into. The 4-door sill cover doesn't have these slots, and is therefore a different part number. Casp23.jpg
Lips
Name Fitted To Features Fitting Picture
Pre-facelift Lip All E30s up to 1987 140px
Facelift Lip All standard E30s from 1987 140px
iS Lip 140px
Volvo Lip 140px
Side Skirts
SE Skirts The Special Equipment sideskirts were fitted as standard to Touring and Cabriolet models, and were also found on all SE models of the 320i and 325i. Each skirt is in two pieces; a main section running under the doors to the rear arch, and a small leading section which covers the lower portion of the front wing. These two parts simply slide and clip together.
Fitting Guide 140px
140px
