M20
Revision as of 21:58, 30 October 2011 by Grrrmachine (talk | contribs)
Models
M20 Oil pump and sump gasket
The M20 oil pump is a gear-driven unit that takes its power from the crank via an intermediate drive shaft. M20 oil pumps are usually very reliable, and only need to be replaced if you have smashed your sump somehow. To remove,
Sump Gasket
M20 Pistons
Ø: 84 84 84 84 84 84 84
ÜH: 4.2 4.2 4.43 3.6 0.65
MT: -6.2 -5.1 1.1 -3.5 -2
Stroke: 75 75 75 81 81 81 81
Piston Shape: 100px 100px 100px 100px 100px 100px 100px
Piston Rings
Crank Pulley
Cam
Rocker Arms
Breather Hose
Engine Mounts
Oil
Oil is picked up by the oil pump and
Oil Cooler
Main article: Cooling
Not Starting
Stroker Engines
Engine Management
Useful websites
See Also
Engines M21 M30
