M20
Revision as of 09:29, 29 October 2011 by Grrrmachine (talk | contribs)
Models
The lowest part of the M20 engine is the Sump, a steel dish that provides an oil bath for the crankshaft, as well as feeding the oil pump.
Sump Gasket
Piston Head
Piston Rings
Crank Pulley
Cam
Rocker Arms
Breather Hose
Engine Mounts
Not Starting
Stroker Engines
Engine Management
Useful websites
See Also
Engines M21 M30
