Revision as of 17:58, 16 November 2011 by Grrrmachine (talk | contribs)
The ECU is the brain of your E30. It is responsible for controlling the operation of the engine
From the first carburetted M10 engines to the sophisticated M42, all E30s features some form of Engine Control Unit that operated some or all of the following features:
The ECU and the system it managed changed incredibly from its first inception in 1982 to the final E30 in 1994. To understand them fully, it is necessary to know what system is fitted to your car
Carburettor
L-Jetronic
Main article: Jetronic
Motronic
Main article: Motronic
The Motronic ECU contains a fuel map with an injector opening time for basic conditions of speed and load. Information is then gathered from engine sensors such as the AFM, CPS, CTS, and TPS. As a result of this information, the ECU will look-up the correct injector pulse duration right across the engine rpm, load and temperature range.
List of ECUs
Table Title
0260 200 005 Carburettor 316 1982-
0280 000 318 L-Jetronic 318i 1983 - 84
0280 000 330 L-Jetronic 318i 1984 - 87
0280 001 301 L-Jetronic 320i and 323i 1982 - 84
0280 001 309 L-Jetronic Later 320i
0280 001 308 L-Jetronic Later 323i
0280 000 310 L-Jetronic Late 323i
0261 200 172 Motronic 320i 1987
0261 200 173 Motronic 325i Plastic bumper 9/87 onwards
0261 200 090 Motronic Evo II
0261 200 092 Motronic Sport Evo
0261 200087 Motronic 320iS
