M52 b30 stroker rebuild back on the road
Could you not see that the valves were iffy when you previously had the head off?
They couldnt have been bent before, the shop that did the skim/pressure test would have picked it upSpeedtouch wrote:Could you not see that the valves were iffy when you previously had the head off?
craigieeb
Thats what I'v been thinking about,
something must of bent them,
But what...
But what...
M50 Turbo!!!
I shall say no more
Overly keen geordie spanner monkey?
Hopefully you wont find that something fell down the port!
i've lost an 11 mm socket
+ a yard full of scrap turds
appletree
I know a scrap yard with a good 2.8 in from and E39. can send you the details if you want. down my way though Retford, notts
i'm hoping that it won't come to that Matt .
4 bent valves removed from pot 6 an 4 straight ones lapped back in.head is just about to be torqued down......
driftwood
How bad were they? Hope it runs nice.
Not a purist.
about a 5-6 out of ten .driftwood wrote:How bad were they? Hope it runs nice.
putting the cams in now oooooh
[youtube][/youtube]
sounds like a 6 to me .
i'll get the zaust on tomorrow and bleed it up,tonight i'm having a happy beer
jimbom30cab
- Tech 1 freak
Good Job !!!!!!!!!!!!!!!!
leeparkes
Neilios
Good stuff, glad it sounds well. Looking forward to seeing it on the road.
craigieeb
Your welcome!
fook the beer! get the exhaust on and get out in it!
M50 Turbo!!!
I shall say no more
'bout foooking time!!!!
Nice feeling though when you get it right. Well done for sticking with it.
craigieeb
Feeling the love mate, feeling the lovemagpie wrote:
you know i luv ya Craig ....in a man hug way with no tongues
But i want to see 11's tomorrow
and into the 13's down the pod.....under your own steam
M50 Turbo!!!
I shall say no more
Finally, it purrs!!
Motorhole
Superb bud, sounds well!
engine no 3 needed FFS!
jimbom30cab
- Tech 1 freak
Hey? What's up?
maggspower
- Turbo Farmer Tractor Driver
FFS
Whats happened?
Whats happened?
Contact: theengineshedonline@gmail.com
Dezzy
- CR24v it's a lifestyle
F0CK OFF.
What now?
What now?
appletree
You must be joking!
gooner1
- Out humping Reindeer
FFS Mick. your'e luck's poxed.
You sure you aint a gooner?
craigieeb
WTF?
whats happened??????
M50 Turbo!!!
I shall say no more
leeparkes
craigieeb
Spoke to him earlier and he's having coolant issues,
After its bled up, taken for a spin, The pipes are rock hard
and when he cracks the bleed screw there just a load of steam.
M50 Turbo!!!
I shall say no more
rich318i
what cooling setup you using magpie?
ie rad the lot? any heat in the car and so on....
heat at the heaters,pipe at bottom of rad is hot [return] fan kicks in .
a/c type e36 rad with e36 twin speed fan with 88 deg fan switch.car was bled with the front end up in the air and fed through the top hose until it spewed out the top hose connection on the rad,connect top hose.
then my own little trick is to block the small hole on the rad just inside the filler cap with my finger so no air can be sucked in and squeeze the drivers side bottom hose until no air bubble appear keeping the fluid topped up.then i'll start the car,run it for a bit and check the top hose and if need be turn the engine off and release the air/pressure via the bleed valve and it then should be done and time for some pollution !
instead after a 10 min drive i have hard rad pipes and air from the bleed valve .
i'm turning into a drunken bum
leeparkes
Drink away Mick, think about it tomorrow.
rich318i
you getting heat in the car via the matrix? did you bled it with the on heating on in the car? the tilt the car while bleeding is just rubbish its just a myth.
