M52 b30 stroker rebuild back on the road
Could you not see that the valves were iffy when you previously had the head off?
- Contact:
They couldnt have been bent before, the shop that did the skim/pressure test would have picked it upSpeedtouch wrote:Could you not see that the valves were iffy when you previously had the head off?
I know a scrap yard with a good 2.8 in from and E39. can send you the details if you want. down my way though Retford, notts
[youtube][/youtube]
sounds like a 6 to me .
i'll get the zaust on tomorrow and bleed it up,tonight i'm having a happy beer
+ a yard full of scrap turds
jimbom30cab
- Tech 1 freak
Good Job !!!!!!!!!!!!!!!!
craigieeb
Feeling the love mate, feeling the lovemagpie wrote:
you know i luv ya Craig ....in a man hug way with no tongues
But i want to see 11's tomorrow
and into the 13's down the pod.....under your own steam
M50 Turbo!!!
I shall say no more
jimbom30cab
- Tech 1 freak
Hey? What's up?
maggspower
- Turbo Farmer Tractor Driver
FFS
Whats happened?
Whats happened?
Contact: theengineshedonline@gmail.com
craigieeb
Spoke to him earlier and he's having coolant issues,
After its bled up, taken for a spin, The pipes are rock hard
and when he cracks the bleed screw there just a load of steam.
M50 Turbo!!!
I shall say no more
heat at the heaters,pipe at bottom of rad is hot [return] fan kicks in .
a/c type e36 rad with e36 twin speed fan with 88 deg fan switch.car was bled with the front end up in the air and fed through the top hose until it spewed out the top hose connection on the rad,connect top hose.
then my own little trick is to block the small hole on the rad just inside the filler cap with my finger so no air can be sucked in and squeeze the drivers side bottom hose until no air bubble appear keeping the fluid topped up.then i'll start the car,run it for a bit and check the top hose and if need be turn the engine off and release the air/pressure via the bleed valve and it then should be done and time for some pollution !
instead after a 10 min drive i have hard rad pipes and air from the bleed valve .
i'm turning into a drunken bum
