M52 b30 stroker rebuild back on the road
Post Thu Aug 15, 2013 1:23 pm
Could you not see that the valves were iffy when you previously had the head off? :?
Post Thu Aug 15, 2013 2:05 pm
Speedtouch wrote:Could you not see that the valves were iffy when you previously had the head off? :?
They couldnt have been bent before, the shop that did the skim/pressure test would have picked it up
craigieeb
Post Thu Aug 15, 2013 2:09 pm
Thats what I'v been thinking about,
something must of bent them,
But what...
Post Thu Aug 15, 2013 2:31 pm
Overly keen geordie spanner monkey? :D
Hopefully you wont find that something fell down the port!
Post Thu Aug 15, 2013 2:38 pm
i've lost an 11 mm socket :mrgreen:
appletree
Post Thu Aug 15, 2013 9:23 pm
I know a scrap yard with a good 2.8 in from and E39. can send you the details if you want. down my way though Retford, notts
Post Fri Aug 16, 2013 9:30 am
i'm hoping that it won't come to that Matt .
Post Fri Aug 16, 2013 3:16 pm
4 bent valves removed from pot 6 an 4 straight ones lapped back in.head is just about to be torqued down......
driftwood
Post Fri Aug 16, 2013 3:26 pm
How bad were they? Hope it runs nice.
Not a purist.
Post Fri Aug 16, 2013 3:37 pm
driftwood wrote:How bad were they? Hope it runs nice.
about a 5-6 out of ten .
putting the cams in now oooooh :)
Post Fri Aug 16, 2013 6:10 pm
[youtube][/youtube]
sounds like a 6 to me .
i'll get the zaust on tomorrow and bleed it up,tonight i'm having a happy beer :D
jimbom30cab
Tech 1 freak
Post Fri Aug 16, 2013 6:21 pm
Good Job !!!!!!!!!!!!!!!!
leeparkes
Post Fri Aug 16, 2013 6:30 pm
:rock:
driftwood
Post Fri Aug 16, 2013 6:38 pm
Tfft!
Not a purist.
Neilios
Post Fri Aug 16, 2013 6:52 pm
Good stuff, glad it sounds well. Looking forward to seeing it on the road.
craigieeb
Post Fri Aug 16, 2013 7:11 pm
Your welcome! :D
fook the beer! get the exhaust on and get out in it!
Post Fri Aug 16, 2013 7:33 pm
it's gonna be weird closing this chapter,that means it's finished<< :D
you know i luv ya Craig ....in a man hug way with no tongues
Post Fri Aug 16, 2013 7:34 pm
'bout foooking time!!!!
Nice feeling though when you get it right. Well done for sticking with it.
craigieeb
Post Fri Aug 16, 2013 7:42 pm
Feeling the love mate, feeling the love
:group:
:lol:
But i want to see 11's tomorrow winkeye
and into the 13's down the pod.....under your own steam :woohoo: :woohoo:
Post Fri Aug 16, 2013 8:07 pm
Finally, it purrs!! :D
Motorhole
Post Fri Aug 16, 2013 10:16 pm
Superb bud, sounds well!
Post Sat Aug 17, 2013 6:01 pm
engine no 3 needed FFS!
jimbom30cab
Tech 1 freak
Post Sat Aug 17, 2013 6:03 pm
Hey? What's up?
maggspower
Turbo Farmer Tractor Driver
Post Sat Aug 17, 2013 6:11 pm
FFS :(
Whats happened?
Dezzy
CR24v it's a lifestyle
Post Sat Aug 17, 2013 6:16 pm
F0CK OFF.
What now?
appletree
Post Sat Aug 17, 2013 6:35 pm
You must be joking! :(
gooner1
Out humping Reindeer
Post Sat Aug 17, 2013 6:44 pm
FFS Mick. your'e luck's poxed.
You sure you aint a gooner? :(
craigieeb
Post Sat Aug 17, 2013 7:00 pm
WTF?
whats happened??????
leeparkes
Post Sat Aug 17, 2013 10:21 pm
:squint:
craigieeb
Post Sat Aug 17, 2013 10:59 pm
Spoke to him earlier and he's having coolant issues,
After its bled up, taken for a spin, The pipes are rock hard
and when he cracks the bleed screw there just a load of steam.
rich318i
Post Sat Aug 17, 2013 11:20 pm
what cooling setup you using magpie?
ie rad the lot? any heat in the car and so on....
Post Sat Aug 17, 2013 11:50 pm
heat at the heaters,pipe at bottom of rad is hot [return] fan kicks in .
a/c type e36 rad with e36 twin speed fan with 88 deg fan switch.car was bled with the front end up in the air and fed through the top hose until it spewed out the top hose connection on the rad,connect top hose.
then my own little trick is to block the small hole on the rad just inside the filler cap with my finger so no air can be sucked in and squeeze the drivers side bottom hose until no air bubble appear keeping the fluid topped up.then i'll start the car,run it for a bit and check the top hose and if need be turn the engine off and release the air/pressure via the bleed valve and it then should be done and time for some pollution !
instead after a 10 min drive i have hard rad pipes and air from the bleed valve .
i'm turning into a drunken bum
:cry:
leeparkes
Post Sat Aug 17, 2013 11:54 pm
Drink away Mick, think about it tomorrow. 8)
Post Sat Aug 17, 2013 11:56 pm
rich318i
Post Sat Aug 17, 2013 11:58 pm
you getting heat in the car via the matrix? did you bled it with the on heating on in the car? the tilt the car while bleeding is just rubbish its just a myth.
