E30 turbo Modification
bonnacab
Ive got a 318is Turbo on a 94 plate "E30"
It needs an exhaust, does anyone know whether or not it needs a cat box?
Has anyone had any past experiance or can give me any advice?
Post back
Post back
CHRISP
- Boost Junkie
bonnacab
do you know of a cat?
and if so which is the best for this conversion?
Jon_Bmw
- Dangerous when thinking
An IS on a 94 plate
maxfield
I thought the same..Jon_Bmw wrote:An IS on a 94 plate
iS engine in a '94 Touring?
bonnacab
ye it is a 94 touring with a turbo conversion project,
can i use the frogmeister an how much bhp would it take?
CHRISP
- Boost Junkie
bonnacab
the car is a 94L but the engine is an M42
bonnacab
who's ant an how do i email him?
Jon_Bmw
It goes on whatevers oldest ratch.
Engine or car. So you don't need one.
Scrap that, I don't think it is ratch? Are you english fella as I can't quite work out what you are saying with the frogmiester comment?
CHRISP
- Boost Junkie
bonnacab
thanks chrisp, your advice may be helpful
Scruffymurphy
I also have a 94 touring with an M42 engine. I'd love to turbo it. What setup have you used?
bonnacab
It was turbo when i bought it about 4 years ago .It ran with standard ecu.chipped,recurculating dump valve .and intercooler.Turbo is a low pressure one,make and what car it came off not sure.Bhp was about 184.Because engine was high compression found out reason for blowing head gasket,valves,guides,rings after about 18 months.....After a head rebuild,new bottom end,decomp plate,turbo rebuild its back.it still needs a few things like stand alone ecu,new exhaust before i can try to get more power gains
